[Swift-commit] r2664 - provenancedb
Mon Mar 9 10:12:24 CDT 2009
Author: benc
Date: 2009-03-09 10:12:24 -0500 (Mon, 09 Mar 2009)
New Revision: 2664
Modified:
   provenancedb/provenance.xml
Log:
note on checking out SVN code in the own-database section
Modified: provenancedb/provenance.xml
--- provenancedb/provenance.xml	2009-03-09 14:46:28 UTC (rev 2663)
+++ provenancedb/provenance.xml	2009-03-09 15:12:24 UTC (rev 2664)
@@ -144,6 +144,19 @@
 <para>This section details running your own SQL-based provenance database on
 servers of your own control.</para>
+<section><title>Check out the latest SVN code</title>
+Use the following two commands to check out the <literal>provenancedb</literal>
+and <literal>log-processing</literal> modules:
+<screen>
+svn co https://svn.ci.uchicago.edu/svn/vdl2/provenancedb
+svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
+</screen>
+</section>
 <section><title>Configuring your SQL database</title>
 <para>
 This section describes configuring the SQL scripts to use
