[Swift-commit] r2662 - provenancedb
Mon Mar 9 09:45:53 CDT 2009
Author: benc
Date: 2009-03-09 09:45:53 -0500 (Mon, 09 Mar 2009)
New Revision: 2662
Modified:
   provenancedb/import-all
Log:
make import-all only do sql, not xml
Modified: provenancedb/import-all
--- provenancedb/import-all	2009-03-09 14:45:19 UTC (rev 2661)
+++ provenancedb/import-all	2009-03-09 14:45:53 UTC (rev 2662)
@@ -39,7 +39,7 @@
      echo ============= will import =============
      ./prepare-for-import $filename
      ./import-run-to-sql $filename
-     ./import-run-to-xml $filename
+#     ./import-run-to-xml $filename
      $SQLCMD -c "INSERT INTO known_workflows (workflow_log_filename, version, importstatus) VALUES ('$filename','$version','imported');"
    else
      echo SKIP: Workflow does not report successful end.
@@ -53,5 +53,5 @@
 # now pull the XML data into eXist, in as few runs as possible to avoid
 # JVM startup.
-ls `pwd`/*.log.xml | time xargs ~/work/eXist/bin/client.sh -m /db/prov -ouri=xmldb:exist:// -p
+# ls `pwd`/*.log.xml | time xargs ~/work/eXist/bin/client.sh -m /db/prov -ouri=xmldb:exist:// -p
