[Swift-commit] r2660 - log-processing/tests/log-processing/make-targets
Mon Mar 9 07:30:36 CDT 2009
Author: benc
Date: 2009-03-09 07:30:35 -0500 (Mon, 09 Mar 2009)
New Revision: 2660
Removed:
   log-processing/tests/log-processing/make-targets/workflow.event.first-r2522.expected
Modified:
   log-processing/tests/log-processing/make-targets/run
Log:
workflow.event contains a full path, so we cannot test using this mechanism -
this commit removes that test case.
Modified: log-processing/tests/log-processing/make-targets/run
--- log-processing/tests/log-processing/make-targets/run	2009-03-09 12:22:24 UTC (rev 2659)
+++ log-processing/tests/log-processing/make-targets/run	2009-03-09 12:30:35 UTC (rev 2660)
@@ -1,6 +1,6 @@
 #!/bin/bash
-TARGETS="execute.event execute2.event execute.global.event workflow.event"
+TARGETS="execute.event execute2.event execute.global.event"
 LOG=$(pwd)/../logs/first-r2522.log
Deleted: log-processing/tests/log-processing/make-targets/workflow.event.first-r2522.expected
--- log-processing/tests/log-processing/make-targets/workflow.event.first-r2522.expected	2009-03-09 12:22:24 UTC (rev 2659)
+++ log-processing/tests/log-processing/make-targets/workflow.event.first-r2522.expected	2009-03-09 12:30:35 UTC (rev 2660)
@@ -1 +0,0 @@
-1236540517.424 3.220 tag:benc at ci.uchicago.edu,2007:swift:run:20090308-2028-mfnmsxx2 /Users/benc/work/swift-svn.git/vdl2/log-processing/tests/log-processing/make-targets/../logs/first-r2522.log
