[Swift-commit] r2633 - provenancedb
Mon Mar 2 11:57:39 CST 2009
Author: benc
Date: 2009-03-02 11:57:38 -0600 (Mon, 02 Mar 2009)
New Revision: 2633
Added:
   provenancedb/drive-opm
   provenancedb/prov-to-opm.sh
Log:
A prototype of a log->OPM XML form converter using a variation of
Luc Moreau's XML schema.
Added: provenancedb/drive-opm
--- provenancedb/drive-opm	                        (rev 0)
+++ provenancedb/drive-opm	2009-03-02 17:57:38 UTC (rev 2633)
@@ -0,0 +1,13 @@
+#!/bin/bash
+# driver for log file -> OPM conversion
+filename=$1
+export PATH=$LOGPATH:$PATH
+echo log to OPM conversion for $filename
+./prepare-for-import $filename
+./prov-to-opm.sh $filename
Property changes on: provenancedb/drive-opm
___________________________________________________________________
Added: provenancedb/prov-to-opm.sh
--- provenancedb/prov-to-opm.sh	                        (rev 0)
+++ provenancedb/prov-to-opm.sh	2009-03-02 17:57:38 UTC (rev 2633)
@@ -0,0 +1,85 @@
+#!/bin/bash
+echo Generating OPM for a single run
+rm -f opm.xml
+# TODO make swift-opm-ns into a proper URI
+echo "<opmGraph xmlns=\"http://openprovenance.org/model/v1.01.a\" xmlns:swift=\"swift-opm-ns\">" > opm.xml
+echo "<accounts><account id=\"base\" /></accounts>" >> opm.xml
+echo "<processes>" >> opm.xml
+while read time duration thread endstate app scratch; do
+echo "  <process id=\"$thread\">"
+echo "    <account id=\"base\" />"
+echo "    <swift:info starttime=\"$starttime\" duration=\"$duration\" endstate=\"$endstate\" app=\"$app\" scratch=\"$scratch\"/>"
+# TODO no value here - this is some URI into an ontology, which is don't
+# really know how should be mapped from Swift
+echo "  </process>"
+done < $LOGDIR/execute.global.event >> opm.xml
+echo "</processes>" >> opm.xml
+# TODO artifacts
+echo "<artifacts>" >> opm.xml
+# we need a list of all artifacts here. for now, take everything we can
+# find in the tie-data-invocs and containment tables, uniquefied.
+# This is probably the wrong thing to do.
+while read outer inner; do
+  echo $input
+  echo $output
+done < $LOGDIR/tie-containers.txt > tmp-dshandles.txt
+while read t d dataset rest ; do
+  echo $dataset
+done < $LOGDIR/tie-data-invocs.txt >> tmp-dshandles.txt
+cat tmp-dshandles.txt | sort | uniq > tmp-dshandles2.txt
+while read artifact ; do
+echo "  <artifact id=\"$artifact\">"
+echo "  </artifact>"
+done < tmp-dshandles2.txt >> opm.xml
+echo "</artifacts>" >> opm.xml
+echo "<causalDependencies>" >> opm.xml
+# other stuff can do this in any order, but here we must probably do it
+# in two passes, one for each relation, in order to satisfy schema.
+# but for now do it in a single pass...
+while read thread direction dataset variable rest; do
+  if [ "$direction" == "input" ] ; then
+    echo "  <used>"
+    echo "    <effect id=\"$thread\" />"
+    echo "    <role value=\"$variable\" />"
+    echo "    <cause id=\"$dataset\" />"
+    echo "    <account id=\"base\" />"
+    echo "  </used>"
+  else
+    echo "  <wasGeneratedBy>"
+    echo "    <effect id=\"$dataset\" />"
+    echo "    <cause id=\"$thread\" />"
+    echo "  </wasGeneratedBy>"
+  fi
+done < $LOGDIR/tie-data-invocs.txt >> opm.xml
+echo "</causalDependencies>" >> opm.xml
+echo "</opmGraph>" >> opm.xml
+echo Finished generating OPM, in opm.xml
Property changes on: provenancedb/prov-to-opm.sh
