[Swift-commit] r2484 - in trunk: docs libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript tests/language-behaviour
Thu Jan 29 12:24:39 CST 2009
Author: hategan
Date: 2009-01-29 12:24:39 -0600 (Thu, 29 Jan 2009)
New Revision: 2484
Added:
   trunk/tests/language-behaviour/0054-strsplit.out.expected
   trunk/tests/language-behaviour/0054-strsplit.swift
Modified:
   trunk/docs/userguide.xml
   trunk/libexec/vdl-lib.xml
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
added strsplit
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-01-29 16:56:02 UTC (rev 2483)
+++ trunk/docs/userguide.xml	2009-01-29 18:24:39 UTC (rev 2484)
@@ -1682,6 +1682,32 @@
 will output the message 'Your name is John'.
 			</para>
 		</section>
+		<section id="function.strsplit"><title>@strsplit</title>
+			<para>
+ at strsplit(input,pattern) will split the input string based on separators
+that match the given pattern and return a string array.
+			</para>
+			<para>
+Example:
+			</para>
+			<programlisting>
+string t = "my name is John and i like puppies.";
+string words[] = @strsplit(t, "\\s");
+foreach word in words {
+	print(word);
+			</programlisting>
+			<para>
+will output one word of the sentence on each line (though
+not necessarily in order, due to the fact that foreach
+iterations execute in parallel).
+			</para>
+		</section>
 		<section id="function.toint"><title>@toint</title>
 			<para>
 @toint(input) will parse its input string into an integer. This can be
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml	2009-01-29 16:56:02 UTC (rev 2483)
+++ trunk/libexec/vdl-lib.xml	2009-01-29 18:24:39 UTC (rev 2484)
@@ -7,6 +7,7 @@
 	<export name="readdata2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData2"/></export>
 	<export name="strcat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2009-01-29 16:56:02 UTC (rev 2483)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2009-01-29 18:24:39 UTC (rev 2484)
@@ -182,6 +182,15 @@
 		strcut.addOutputArg(strcutOut1);
 		functionsMap.put(strcut.getName(), strcut);
+		ProcedureSignature strsplit = new ProcedureSignature("strsplit");
+        FormalArgumentSignature strsplitIn1 = new FormalArgumentSignature("string");
+        strsplit.addInputArg(strsplitIn1);
+        FormalArgumentSignature strsplitIn2 = new FormalArgumentSignature("string");
+        strsplit.addInputArg(strsplitIn2);
+        FormalArgumentSignature strsplitOut1 = new FormalArgumentSignature("string[]");
+        strsplit.addOutputArg(strsplitOut1);
+        functionsMap.put(strsplit.getName(), strsplit);
 		ProcedureSignature toint = new ProcedureSignature("toint");
 		FormalArgumentSignature tointIn1 = new FormalArgumentSignature("string");
 		toint.addInputArg(tointIn1);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2009-01-29 16:56:02 UTC (rev 2483)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2009-01-29 18:24:39 UTC (rev 2484)
@@ -12,6 +12,8 @@
 import org.griphyn.vdl.karajan.lib.SwiftArg;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.InvalidPathException;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.RootArrayDataNode;
 import org.griphyn.vdl.mapping.RootDataNode;
 import org.griphyn.vdl.type.NoSuchTypeException;
 import org.griphyn.vdl.type.Types;
@@ -28,6 +30,7 @@
 		setArguments("swiftscript_trace", new Arg[] { Arg.VARGS });
 		setArguments("swiftscript_strcat", new Arg[] { Arg.VARGS });
 		setArguments("swiftscript_strcut", new Arg[] { PA_INPUT, PA_PATTERN });
+		setArguments("swiftscript_strsplit", new Arg[] { PA_INPUT, PA_PATTERN });
 		setArguments("swiftscript_regexp", new Arg[] { PA_INPUT, PA_PATTERN, PA_TRANSFORM });
 		setArguments("swiftscript_toint", new Arg[] { PA_INPUT });
@@ -88,6 +91,22 @@
 		handle.closeShallow();
 		return handle;
+	public DSHandle swiftscript_strsplit(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+            InvalidPathException {
+        String str = TypeUtil.toString(PA_INPUT.getValue(stack));
+        String pattern = TypeUtil.toString(PA_PATTERN.getValue(stack));
+        String[] split = str.split(pattern);
+        DSHandle handle = new RootArrayDataNode(Types.STRING.arrayType());
+        for (int i = 0; i < split.length; i++) {
+            DSHandle el = handle.getField(Path.EMPTY_PATH.addFirst(String.valueOf(i), true));
+            el.setValue(split[i]);
+        handle.closeDeep();
+        return handle;
 	public DSHandle swiftscript_regexp(VariableStack stack) throws ExecutionException, NoSuchTypeException,
Added: trunk/tests/language-behaviour/0054-strsplit.out.expected
--- trunk/tests/language-behaviour/0054-strsplit.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/0054-strsplit.out.expected	2009-01-29 18:24:39 UTC (rev 2484)
@@ -0,0 +1 @@
+ab , c , def , ghij
Added: trunk/tests/language-behaviour/0054-strsplit.swift
--- trunk/tests/language-behaviour/0054-strsplit.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/0054-strsplit.swift	2009-01-29 18:24:39 UTC (rev 2484)
@@ -0,0 +1,14 @@
+type messagefile {}
+(messagefile t) greeting(string a, string b, string c, string d) {
+    app {
+        echo a "," b "," c "," d stdout=@filename(t);
+messagefile outfile <"0054-strsplit.out">;
+string s[] = @strsplit("ab c def ghij", "\\s");
+outfile = greeting(s[0], s[1], s[2], s[3]);
