[Swift-commit] r2482 - trunk/docs
Thu Jan 29 09:40:38 CST 2009
Author: benc
Date: 2009-01-29 09:40:38 -0600 (Thu, 29 Jan 2009)
New Revision: 2482
Modified:
   trunk/docs/userguide.xml
Log:
formatting of tc.data section
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-01-29 15:38:45 UTC (rev 2481)
+++ trunk/docs/userguide.xml	2009-01-29 15:40:38 UTC (rev 2482)
@@ -2852,7 +2852,7 @@
 		</para>
 		<para>
 By default, the site catalog is stored in <filename>etc/tc.data</filename>.
-This path can be overridden with the tc.file configuration property,
+This path can be overridden with the <literal>tc.file</literal> configuration property,
 either in the Swift configuration file or on the command line.
 		</para>
 		<para>
@@ -2874,7 +2874,7 @@
 catalog.</para>
 		<para>
 The transformation name should correspond to the transformation name
-used in a SwiftScript app {} block.
+used in a SwiftScript <literal>app</literal> procedure.
 		</para>
 		<para>
 The executable path should specify where the particular executable is
@@ -2882,10 +2882,10 @@
 		</para>
 		<para>
 The installation status and platform fields are not used. Set them to
-INSTALLED and INTEL32::LINUX respectively.
+<literal>INSTALLED</literal> and <literal>INTEL32::LINUX</literal> respectively.
 		</para>
 		<para>
-The profiles field should be set to 'null' if no profile entries are to be
+The profiles field should be set to <literal>null</literal> if no profile entries are to be
 specified, or should contain the profile entries separated by semicolons.
 		</para>
 	</section>
