[Swift-commit] r2462 - trunk/docs
Wed Jan 28 08:24:10 CST 2009
Author: benc
Date: 2009-01-28 08:24:09 -0600 (Wed, 28 Jan 2009)
New Revision: 2462
Modified:
   trunk/docs/userguide.xml
Log:
crosslink filesys mapper
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-01-28 14:21:39 UTC (rev 2461)
+++ trunk/docs/userguide.xml	2009-01-28 14:24:09 UTC (rev 2462)
@@ -180,8 +180,8 @@
 Arrays of values can be delcared using the <literal>[]</literal> suffix. An
 array be mapped to a collection of files, one element per file, by using
 a different form of mapping expression.  For example, the
-<literal>filesys_mapper</literal> maps all files matching a particular
-unix glob pattern into an array:
+<link linkend="mapper.filesys_mapper"><literal>filesys_mapper</literal></link>
+maps all files matching a particular unix glob pattern into an array:
 </para>
 <programlisting>
