[Swift-commit] r2447 - trunk/docs
Mon Jan 19 10:23:58 CST 2009
Author: benc
Date: 2009-01-19 10:23:58 -0600 (Mon, 19 Jan 2009)
New Revision: 2447
Modified:
   trunk/docs/userguide.xml
Log:
further status.mode documentation
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-01-19 16:15:28 UTC (rev 2446)
+++ trunk/docs/userguide.xml	2009-01-19 16:23:58 UTC (rev 2447)
@@ -1738,7 +1738,7 @@
 be used. Notably, GRAM2 does not return job statuses correctly, and so
 <literal>provider</literal> mode will not work with GRAM2. With other
 providers, it can be used to reduce the amount of filesystem access compared
-to <literal>files</literal> mode.
+to <literal>files</literal> mode. (since Swift 0.8)
 							</para>
 						</listitem>
 					</varlistentry>
@@ -2320,6 +2320,9 @@
 			<para id="profile.karajan.delayBase">delayBase - controls how much a site will be delayed when it performs poorly. With each reduction
 in a sites score by 1, the delay between execution attempts will increase by
 a factor of delayBase.</para>
+			<para id="profile.karajan.status.mode">status.mode - allows the status.mode property to be set per-site instead of for an entire run.
+See the Swift configuration properties section for more information.
+(since Swift 0.8)</para>
 		</section>
 		<section id="profile.swift"><title>swift namespace</title>
 			<para id="profile.swift.storagesize">storagesize limits the
