[Swift-commit] r2428 - trunk/src/org/griphyn/vdl/mapping
Sat Jan 10 11:01:12 CST 2009
Author: benc
Date: 2009-01-10 11:01:10 -0600 (Sat, 10 Jan 2009)
New Revision: 2428
Modified:
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/DSHandle.java
   trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
Log:
separate getIdentifyingString method for presenting in log
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-01-10 15:32:59 UTC (rev 2427)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2009-01-10 17:01:10 UTC (rev 2428)
@@ -97,13 +97,26 @@
 				return this.value.toString();
+		return getIdentifyingString();
+	public String getIdentifyingString() {
 		String prefix = this.getClass().getName();
 		prefix = prefix + " identifier "+this.getIdentifier();
- 		prefix = prefix + " with no value at dataset=";
+		prefix = prefix + " type "+getType();
+		if(value == null) {
+ 			prefix = prefix + " with no value at dataset=";
+		} else if (value instanceof Throwable) {
+			prefix = prefix + " containing throwable "+value.getClass();
+		} else {
+ 			prefix = prefix + " value="+this.value.toString()+" dataset=";
 		prefix = prefix + getDisplayableName();
 		if (!Path.EMPTY_PATH.equals(getPathFromRoot())) {
@@ -118,6 +131,7 @@
 		return prefix;
 	protected String getDisplayableName() {
@@ -348,7 +362,7 @@
 	public synchronized void closeShallow() {
 		this.closed = true;
 		notifyListeners();
-		logger.info("closed "+this.getIdentifier());
+		logger.info("closed "+this.getIdentifyingString());
 // so because its closed, we can dump the contents
 		try {
 			logContent();
@@ -450,7 +464,7 @@
 	public synchronized void addListener(DSHandleListener listener) {
 		if (logger.isInfoEnabled()) {
 Exception e = new Exception("To get stack trace");
-			logger.info("Adding handle listener \"" + listener + "\" to \"" + this + "\"", e);
+			logger.info("Adding handle listener \"" + listener + "\" to \"" + getIdentifyingString() + "\"", e);
 		if (listeners == null) {
 			listeners = new LinkedList();
@@ -468,7 +482,7 @@
 				DSHandleListener listener = (DSHandleListener) i.next();
 				i.remove();
-					logger.info("Notifying listener \"" + listener + "\" about \"" + this + "\"");
+					logger.info("Notifying listener \"" + listener + "\" about \"" + getIdentifyingString() + "\"");
 				listener.handleClosed(this);
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2009-01-10 15:32:59 UTC (rev 2427)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2009-01-10 17:01:10 UTC (rev 2428)
@@ -83,5 +83,7 @@
     public String getIdentifier();
+    public String getIdentifyingString();
     public boolean isRestartable();
Modified: trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java	2009-01-10 15:32:59 UTC (rev 2427)
+++ trunk/src/org/griphyn/vdl/mapping/ExternalDataNode.java	2009-01-10 17:01:10 UTC (rev 2428)
@@ -115,6 +115,10 @@
 		return prefix;
+		return toString();
 	public DSHandle getRoot() {
 		return this;
