[Swift-commit] r2605 - trunk/docs
Wed Feb 25 10:00:07 CST 2009
Author: benc
Date: 2009-02-25 10:00:06 -0600 (Wed, 25 Feb 2009)
New Revision: 2605
Modified:
   trunk/docs/userguide.xml
Log:
fix incorrect references to external data type as 'extern'
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-02-24 17:00:28 UTC (rev 2604)
+++ trunk/docs/userguide.xml	2009-02-25 16:00:06 UTC (rev 2605)
@@ -416,7 +416,7 @@
 Sometimes data may be stored in a form that does not fit with Swift's
 file-and-site model; for example, data might be stored in an RDBMS on some
 database server. In that case, a variable can be declared to have
-<firstterm><literal>extern</literal></firstterm> type. This indicates that
+<firstterm><literal>external</literal></firstterm> type. This indicates that
 Swift should use the variable to determine execution dependency, but should
 not attempt other data management; for example, it will not perform any form
 of data stage-in or stage-out it will not manage local data caches on sites;
@@ -428,15 +428,15 @@
 <programlisting>
   type file;
-  app (extern o) populateDatabase() {
+  app (external o) populateDatabase() {
     populationProgram;
-  app (file o) analyseDatabase(extern i) {
+  app (file o) analyseDatabase(external i) {
     analysisProgram @o;
-  extern database;
+  external database;
   file result <"results.txt">;
   database = populateDatabase();
@@ -1654,9 +1654,9 @@
 <listitem><para>
 that files can be passed(?def) between application procedure invocations
 through any mechanism except through files known to Swift through the
-mapping mechanism (there is some exception here for <literal>extern</literal>
+mapping mechanism (there is some exception here for <literal>external</literal>
 datasets - there are a separate set of assertions that hold for
-<literal>extern</literal> datasets)
+<literal>external</literal> datasets)
 </para></listitem>
 <listitem><para>
