[Swift-commit] r2584 - trunk/src/org/griphyn/vdl/util
Sun Feb 22 11:26:28 CST 2009
Author: benc
Date: 2009-02-22 11:26:27 -0600 (Sun, 22 Feb 2009)
New Revision: 2584
Modified:
   trunk/src/org/griphyn/vdl/util/TriStateBoolean.java
Log:
Tidy whitespace
Modified: trunk/src/org/griphyn/vdl/util/TriStateBoolean.java
--- trunk/src/org/griphyn/vdl/util/TriStateBoolean.java	2009-02-22 17:02:54 UTC (rev 2583)
+++ trunk/src/org/griphyn/vdl/util/TriStateBoolean.java	2009-02-22 17:26:27 UTC (rev 2584)
@@ -4,7 +4,7 @@
 package org.griphyn.vdl.util;
 public final class TriStateBoolean {
-	public static final TriStateBoolean FALSE = new TriStateBoolean(0);
+    public static final TriStateBoolean FALSE = new TriStateBoolean(0);
     public static final TriStateBoolean TRUE = new TriStateBoolean(1);
     public static final TriStateBoolean MAYBE = new TriStateBoolean(2);
@@ -14,36 +14,36 @@
         this.value = value;
-	public boolean equals(Object obj) {
-		if (obj instanceof TriStateBoolean) {
-			return value == ((TriStateBoolean) obj).value;
+    public boolean equals(Object obj) {
+        if (obj instanceof TriStateBoolean) {
+            return value == ((TriStateBoolean) obj).value;
         else {
-        	return false;
+            return false;
-	public int hashCode() {
-		return value;
+    public int hashCode() {
+        return value;
-	public String toString() {
-		switch(value) {
+    public String toString() {
+        switch(value) {
             case 0: return "false";
             case 1: return "true";
             default: return "maybe";
     public static TriStateBoolean valueOf(String value) {
-    	if ("false".equalsIgnoreCase(value) || "no".equalsIgnoreCase(value)) {
-    		return FALSE;
+        if ("false".equalsIgnoreCase(value) || "no".equalsIgnoreCase(value)) {
+            return FALSE;
         else if ("true".equalsIgnoreCase(value) || "yes".equalsIgnoreCase(value)) {
             return TRUE;
         else {
-        	return MAYBE;
+            return MAYBE;
