[Swift-commit] r2569 - SwiftApps/adem-osg
Wed Feb 18 15:19:09 CST 2009
Author: houzx
Date: 2009-02-18 15:19:08 -0600 (Wed, 18 Feb 2009)
New Revision: 2569
Removed:
   SwiftApps/adem-osg/setup.sh
Log:
delete the old setup.sh
Deleted: SwiftApps/adem-osg/setup.sh
--- SwiftApps/adem-osg/setup.sh	2009-02-18 20:13:54 UTC (rev 2568)
+++ SwiftApps/adem-osg/setup.sh	2009-02-18 21:19:08 UTC (rev 2569)
@@ -1,66 +0,0 @@
-#!/bin/bash
-# set-up environment to run Adem - source me
-dir=`basename $PWD`
-Def_Rep="http://www.ci.uchicago.edu/~houzx/pac-cache"
-if [ "X${GLOBUS_LOCATION}" == "X" ]; then
-   echo "NO GLOBUS Error!"
-else if [ $dir != "adem-osg" ]; then
-   echo "Please cd to adem-osg for first setup!"
-   else if [ "X${ADEM_HOME}" == "X" ]; then
-   echo "export ADEM_HOME=$PWD" >> $HOME/.bashrc
-   echo "export PATH=\$PATH:$PWD/bin" >> $HOME/.bashrc
-       else if [ "${ADEM_HOME}" != "$PWD" ]; then
-      sed -i "s,${ADEM_HOME},$PWD,g" $HOME/.bashrc
-       fi
-#   source $HOME/.bashrc
-   fi
-fi
-fi
-#check the grid proxy
-grid-proxy-info 1>/dev/null 2>/dev/null
-if [ "$?" != 0 ]; then
-  echo "ERROR: Couldn not find a valid proxy, Please check your grid proxy!"
-  exit 1
-  else
-  timel=`grid-proxy-info  |grep timeleft |cut -d: -f2`
-  if [ "$timel" -lt 1 ]; then
-  echo "Proxy has less than 60 minutes remainging - exiting."
-  exit
-  fi
-fi
-#check pacman
-if [ "X$PACMAN_LOCATION" == "X" ]; then
-/bin/tar -C $ADEM_HOME  -zxf $ADEM_HOME/doc/pacman-3.21.tar.gz
-cd $ADEM_HOME/pacman-3.21
-source setup.sh 2>/dev/null
-echo "cd $ADEM_HOME/pacman-3.21" >> $ADEM_HOME/pac-set.sh
-echo "source setup.sh 2>/dev/null" >> $ADEM_HOME/pac-set.sh
-echo "source $ADEM_HOME/pac-set.sh" >>  $HOME/.bashrc
-fi
-#check application software repository
-if [ "X$REPOSITORY_HOME" == "X" ]; then
-   echo "The default application software repository is:"
-   echo "$Def_Rep"
-   echo "Do you want to set up your own repository?y or n"
-   read response
-   if [ "$response" == "y" ];then
-   echo "Please input your own application software repository:"
-   read rep
-   echo "OK, you should maintain your own repository, to add,update,or remove the pacman files and software packages."
-   echo "export REPOSITORY_HOME=$rep" >> $HOME/.bashrc
-   else
-   echo "export REPOSITORY_HOME=$Def_Rep" >> $HOME/.bashrc
-   fi
-   source $HOME/.bashrc
-fi
