[Swift-commit] r2563 - in trunk: . docs
Tue Feb 17 10:43:48 CST 2009
Author: benc
Date: 2009-02-17 10:43:47 -0600 (Tue, 17 Feb 2009)
New Revision: 2563
Modified:
   trunk/CHANGES.txt
   trunk/docs/userguide.xml
Log:
Some details OSG/ReSS interface in CHANGES and userguide.
Modified: trunk/CHANGES.txt
--- trunk/CHANGES.txt	2009-02-17 16:43:04 UTC (rev 2562)
+++ trunk/CHANGES.txt	2009-02-17 16:43:47 UTC (rev 2563)
@@ -1,3 +1,9 @@
+(02/09/17)
+*** There is a new command swift-osg-ress-site-catalog which will generate
+    a site catalog based on data gathered from OSG's ReSS information
+    system. This can be used by OSG users to easily generate a large number
+    of site catalog entries for sites that are likely to work.
 (02/09/14)
 *** Handling of [*] and . has changed. [*] has been broken for several
     Swift releases, but now has some approximation of its former behaviour,
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-02-17 16:43:04 UTC (rev 2562)
+++ trunk/docs/userguide.xml	2009-02-17 16:43:47 UTC (rev 2563)
@@ -3563,6 +3563,36 @@
 mpirun command should be explicitly invoked.
 </para>
 		</section>
+		<section id="tips.osg"><title>Generating a sites.xml for OSG</title>
+			<para>
+The Swift distribution contains a command
+<command>swift-osg-ress-site-catalog</command> that can generate a site
+catalog based on OSG's ReSS information system (since Swift 0.9)
+			</para>
+			<screen>
+Usage:
+    swift-osg-ress-site-catalog [options]
+Options:
+    --help  Show this help message
+    --vo=[name]
+            Set what VO to query ReSS for
+    --engage-verified
+            Only retrieve sites verified by the Engagement VO site
+            verification tests This can not be used together with --vo, as
+            the query will only work for sites advertising support for the
+            Engagement VO.
+            This option means information will be retrieved from the
+            Engagement collector instead of the top-level ReSS collector.
+    --out=[filename]
+            Write to [filename] instead of stdout
+			</screen>
+		</section>
 	</section>
