[Swift-commit] r2525 - in trunk/src/org/griphyn/vdl/karajan/lib: . replication
Wed Feb 11 19:16:27 CST 2009
Author: hategan
Date: 2009-02-11 19:16:26 -0600 (Wed, 11 Feb 2009)
New Revision: 2525
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
   trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java
Log:
moved walltime check to TCProfile to avoid passing the tr in an attribute (which causes GT2 to bark)
Modified: trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2009-02-11 15:17:05 UTC (rev 2524)
+++ trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2009-02-12 01:16:26 UTC (rev 2525)
@@ -3,11 +3,15 @@
 package org.griphyn.vdl.karajan.lib;
+import java.util.Collections;
 import java.util.HashMap;
+import java.util.HashSet;
 import java.util.Iterator;
 import java.util.List;
 import java.util.Map;
+import java.util.Set;
+import org.globus.cog.abstraction.impl.common.execution.WallTime;
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.arguments.ArgUtil;
 import org.globus.cog.karajan.arguments.NamedArguments;
@@ -67,9 +71,50 @@
 			attrs = attributesFromTC(tce, attrs);
+		attrs = checkWalltime(tr, attrs);
 		addAttributes(named, attrs);
 		return null;
+	private Map checkWalltime(String tr, Map attrs) {
+	    Object walltime = null;
+	    if (attrs != null) {
+	    	walltime = attrs.get("maxwalltime");
+        if (walltime == null) {
+            warn(tr, "Warning: missing walltime specification for \"" + tr
+                    + "\". Assuming 10 minutes.");
+            walltime = "10";
+        int seconds;
+        try {
+            seconds = WallTime.timeToSeconds(walltime.toString());
+        catch (IllegalArgumentException e) {
+            warn(tr, "Warning: invalid walltime specification for \"" + tr
+                    + "\" (" + walltime + "). Assuming 10 minutes.");
+            walltime = "10";
+        if (attrs == null) {
+            attrs = Collections.singletonMap("maxwalltime", walltime);
+        else {
+            attrs.put("maxwalltime", walltime);
+        return attrs;
+	private static final Set warnedAboutWalltime = new HashSet();
+	private void warn(String tr, String message) {
+        synchronized (warnedAboutWalltime) {
+            if (warnedAboutWalltime.add(tr)) {
+                System.out.println(message);
 	private void addEnvironment(Map m, TransformationCatalogEntry tce) {
 		List l = tce.getProfiles(Profile.ENV);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java
--- trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java	2009-02-11 15:17:05 UTC (rev 2524)
+++ trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java	2009-02-12 01:16:26 UTC (rev 2525)
@@ -93,38 +93,14 @@
-    private static final Set warnedAboutWalltime = new HashSet();
     protected void registerRunning(Task task, Date time) {
         JobSpecification spec = (JobSpecification) task.getSpecification();
         Object walltime = spec.getAttribute("maxwalltime");
-        String tr = (String) spec.getAttribute("tr");
-        if (walltime == null) {
-            warn(tr, "Warning: missing walltime specification for \"" + tr
-                    + "\". Assuming 10 minutes.");
-            walltime = "10";
-        int seconds;
-        try {
-            seconds = WallTime.timeToSeconds(walltime.toString());
-        catch (IllegalArgumentException e) {
-            warn(tr, "Warning: invalid walltime specification for \"" + tr
-                    + "\" (" + walltime + "). Assuming 10 minutes.");
-            seconds = 10 * 60;
+        int seconds = WallTime.timeToSeconds(walltime.toString());
         Date deadline = new Date(time.getTime() + WALLTIME_DEADLINE_MULTIPLIER * seconds * 1000);
         running.put(task, deadline);
-    private void warn(String tr, String message) {
-        synchronized (warnedAboutWalltime) {
-            if (warnedAboutWalltime.add(tr)) {
-                System.out.println(message);
     public synchronized int getN() {
         return n;
