[Swift-commit] r2522 - trunk/docs
Mon Feb 9 09:15:00 CST 2009
Author: benc
Date: 2009-02-09 09:14:59 -0600 (Mon, 09 Feb 2009)
New Revision: 2522
Modified:
   trunk/docs/userguide.xml
Log:
reference from coasters section to coaster-relevant profile keys
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-02-09 15:00:07 UTC (rev 2521)
+++ trunk/docs/userguide.xml	2009-02-09 15:14:59 UTC (rev 2522)
@@ -3475,6 +3475,22 @@
 of a coaster head job, not for file transfer; so for example, a GRAM
 endpoint should be specified here rather than a GridFTP endpoint.
 </para>
+<para>
+Coasters are affected by the following profile settings, which are
+documented in the <link linkend="profile.globus">Globus namespace profile
+section</link>:
+</para>
+<table frame="all">
+ <tgroup cols="2" align="left" colsep="1" rowsep="1">
+  <thead><row><entry>profile key</entry><entry>brief description</entry></row></thead>
+  <tbody>
+   <row><entry>coastersPerNode</entry><entry>How many coasters to run per execution node</entry></row>
+   <row><entry>coasterWorkerMaxwalltime</entry><entry>The maxwalltime that coaster workers should be submitted with</entry></row>
+   <row><entry>coasterInternalIP</entry><entry>The IP address of the coaster head node to be used by workers</entry></row>
+  </tbody>
+ </tgroup>
+</table>
 	</section>
 	<section id="localhowtos"><title>How-To Tips for Specific User Communities</title>
 		<section id="savinglogs"><title>Saving Logs - for UChicago CI Users</title>
