[Swift-commit] r2495 - trunk/docs
Thu Feb 5 07:17:38 CST 2009
Author: benc
Date: 2009-02-05 07:17:37 -0600 (Thu, 05 Feb 2009)
New Revision: 2495
Modified:
   trunk/docs/userguide.xml
Log:
typo
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-02-03 21:54:45 UTC (rev 2494)
+++ trunk/docs/userguide.xml	2009-02-05 13:17:37 UTC (rev 2495)
@@ -1929,7 +1929,7 @@
 <programlisting>
 string v =  @regexp("abcdefghi", "c(def)g","monkey");
 </programlisting>
-will assing the value "abmonkeyhi" to the variable v.
+will assign the value "abmonkeyhi" to the variable v.
 			</para>
 		</section>
 		<section id="function.strcat"><title>@strcat</title>
