[Swift-commit] r3072 - SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/scripts
Thu Aug 6 18:44:50 CDT 2009
Author: andric
Date: 2009-08-06 18:44:50 -0500 (Thu, 06 Aug 2009)
New Revision: 3072
Added:
   SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/scripts/insert_to_db.py
Log:
used to insert ss files into the db
Added: SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/scripts/insert_to_db.py
--- SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/scripts/insert_to_db.py	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/scripts/insert_to_db.py	2009-08-06 23:44:50 UTC (rev 3072)
@@ -0,0 +1,43 @@
+#!/usr/bin/python
+import os
+import sys
+import commands
+import MySQLdb
+import time
+subjs = [3,5,6,7,8,10,11,12,13,14,15,17,18,19,20,21,22,23,24,25,26,27,28,30]
+#subjs = [3]
+hemis = ['lh','rh']
+ccfInterpDir = os.getenv("cnari")+"/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/"
+#---- defining the insert statement function that is going to be run
+def insertdata_to_db(h,ss):
+    print "que hora es?\n"+time.ctime()
+    try:
+        file = "'"+ccfInterpDir+"ss"+`ss`+"interp_results/fordb_ss"+`ss`+"_"+h+".txt'"
+        print "File loading: "+file
+        insert_statement = "load data local infile "+file+" into table interpCCF_"+h+" fields terminated by ' ';"
+        print "Insert statement: "+insert_statement
+        cursor.execute(insert_statement)
+        print "Number of rows inserted %d" % cursor.rowcount
+    except MySQLdb.Error, e:
+        print "Error during "+h+" "+`ss`+" inserting %d -->> %s" % (e.args[0], e.args[1])
+        sys.exit (1)
+#---- establishing connection to the db
+try:
+    connection = MySQLdb.connect(read_default_file="~/.my.cnf",db="EMBLEM1")
+except MySQLdb.Error, e:
+    print "Error %d: %s" % (e.args[0], e.args[1])
+    sys.exit (1)
+cursor = connection.cursor()
+#---- running the insert statement function through the loops
+for h in hemis:
+    for ss in subjs:
+        insertdata_to_db(h,ss)
