[Swift-commit] r3070 - in SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain: . Rscripts
Thu Aug 6 11:03:58 CDT 2009
Author: andric
Date: 2009-08-06 11:03:58 -0500 (Thu, 06 Aug 2009)
New Revision: 3070
Added:
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/peakfitv2v1.R
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/preprocessEnewsmooth.R
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/subqrymediator.R
Log:
R code for doing peak analysis
Added: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/peakfitv2v1.R
--- SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/peakfitv2v1.R	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/peakfitv2v1.R	2009-08-06 16:03:58 UTC (rev 3070)
@@ -0,0 +1,385 @@
+# Savitzky-Golay Algorithm
+# T2 <- sav.gol(T, fl, forder, dorder);
+# Polynomial filtering method of Savitzky and Golay
+# See Numerical Recipes, 1992, Chapter 14.8, for details.
+# T = vector of signals to be filtered
+# (the derivative is calculated for each ROW)
+# fl = filter length (for instance fl = 51..151)
+# forder = filter order (2 = quadratic filter, 4= quartic)
+# dorder = derivative order (0 = smoothing, 1 = first derivative, etc.)
+sav.gol <- function(T, fl, forder, dorder)
+    m <- length(T)
+    dorder <- dorder + 1
+    # -- calculate filter coefficients --
+    fc <- (fl-1)/2 # index: window left and right
+    X <- outer(-fc:fc, 0:forder, FUN="^") # polynomial terms and
+coefficients
+    Y <- pinv(X); # pseudoinverse
+    # -- filter via convolution and take care of the end points --
+    T2 <- convolve(T, rev(Y[dorder,]), type="o") # convolve(...)
+    T2 <- T2[(fc+1):(length(T2)-fc)]
+# *** PseudoInvers of a Matrix ***
+# using singular value decomposition
+pinv <- function (A)
+    s <- svd(A)
+    s$v %*% diag(1/s$d) %*% t(s$u)
+#------------gamma function used in peakfit-------------------------------------------
+# 			|	x-a1  | | (x-a1)/a2 + a3 -1  |^(a3-1)
+# y = a0*exp|- -------|*| ------------------ |
+#			|    a2   | |        a3-1        |
+# a0 = amplitude
+# a1 = center
+# a2 = width (>0)
+# a3 = shape (> 1.01, < 167.92)
+f_peakfit <- function(a0,a1,a2,a3,n,x) {
+	expr <- rep(c(0),length(x));
+	for (i in 1:n)
+    tmp <- rep(c(0),length(x))
+	tmp <- a0[i]*exp(-(x - a1[i])/a2[i])*((x - a1[i])/(a2[i]*(a3[i] - 1)) + 1 )^(a3[i] - 1);
+#   when { b[i]/shape*(x -center[i]) + 1 } < 0, the power is meaningless. tmp[j] is "NaN" and will be replaced by zero
+	for (j in 1:length(x)) {if (tmp[j] == "NaN") {tmp[j] = 0} }
+	expr <- expr + tmp
+	eval(expr)
+# define the function (a kind of simplified version from above) to be used to fit the data
+# y = a*exp(-b*(x - center))*(b/shape*(x - center) + 1)^(shape)
+# a = amplitude
+# b = decay parameter (correspond to 1/a2)
+# center = a1;
+# shape = a3 - 1; later shape will be fixed as 8.6, which is a common number used in most of fMRI study
+# the following is a summation of gmma functions to fit raw data
+# assumption: linear system
+# x is the time points
+# n is the number of peaks detected by second derivatives
+# a, b and center are the parameters defined above and need to be estimated
+# a, b and center are vectors with length corresponding to the number of peaks
+# shape is fixed at 8.6 in all the following analysis
+shape = 8.6
+f <- function(a,b,center,n,x) {
+	shape = 8.6;
+	for (i in 1:n)
+	tmp <- a[i]*exp(-b[i]*(x - center[i]))*(b[i]/shape*(x -center[i]) + 1 )^shape
+	eval(expr)
+# linear square fit, minmize funtion 0.5*|y - y_hat|^2.
+# Use as an input function for constraint estimation
+fcn_L2 <- function(par,n,x,y_and_noise,fcall) {
+	a <- par[1:n]
+	b <- par[(n+1):(2*n)]
+	center <- par[(2*n+1):(3*n)]
+	new_par <- c(list(a = a),list(b = b),list(center = center))
+	res <- (y_and_noise - do.call("fcall",c( as.list(new_par), list(n = n), list(x = x) )  ));
+	0.5*t(res) %*% res
+# a = amplitude
+# center = a1;
+# df_a = exp(-b*(x - center))*(b/shape*(x - center) + 1)^(shape)
+# df_b = a*(-(x-center))*exp(-b*(x - center))*(b/shape*(x - center) + 1)^(shape) + a*exp(-b*(x - center))*shape*(b/shape*(x - center) + 1)^(shape-1)*(x - center)/shape
+# df_center = a*b*exp(-b*(x - center))*(b/shape*(x - center) + 1)^(shape) + a*exp(-b*(x - center))*shape*(b/shape*(x - center) + 1)^(shape-1)*(-b/shape)
+D_fcn_L2 <- function(par,n,x,y_and_noise,fcall) {
+    df_a <- matrix(rep(c(0),n*length(x)),ncol = n, nrow = length(x))
+	df_b <- matrix(rep(c(0),n*length(x)),ncol = n, nrow = length(x))
+	df_center <- matrix(rep(c(0),n*length(x)),ncol = n, nrow = length(x))
+	a <- par[1:n]
+	for (i in 1:n) {
+	   df_a[,i] <- exp(-b[i]*(x - center[i]))*(b[i]/shape *(x -center[i]) + 1 )^shape
+	   df_b[,i] <- a[i]*(-(x - center[i]))*exp(-b[i]*(x - center[i]))*(b[i]/shape *(x -center[i]) + 1 )^shape + a[i]*exp(-b[i]*(x - center[i]))*shape*(b[i]/shape*(x -center[i]) + 1 )^(shape - 1)*(x - center[i])/shape
+	   df_center[,i] <- a[i]*b[i]*exp(-b[i]*(x - center[i]))*(b[i]/shape *(x -center[i]) + 1 )^shape + a[i]*exp(-b[i]*(x - center[i]))*shape*(b[i]/shape*(x -center[i]) + 1 )^(shape -1 )*(-b[i]/shape)
+	tmp <- cbind(df_a,df_b,df_center)
+	for (i in 1:(dim(tmp)[1]) ) {
+		for (j in 1:(dim(tmp)[2]) ) {
+			if (tmp[i,j] == "NaN") {tmp[i,j] = 0}
+	j_f <- tmp
+	y_eval <- do.call("fcall",c(list(a = a), list(b = b), list(center = center), list(n = n), list(x = x)))
+	t(j_f) %*% (y_eval - y_and_noise)
+#---- deriv 3-------------------------------------------------------------
+D_individual_f <- deriv3(
+	~a*exp(-b*(x - center))*(b/shape*(x -center) + 1 )^shape,
+	c("a","b","center"),
+	function(a,b,center,x,shape) {})
+test_D_fcn_L2 <- function(par,n,x,y_and_noise,fcall) {
+	shape = 8.6
+	a <- par[1:n]
+	for (i in 1:n) {
+	   tmp <- D_individual_f(a[i],b[i],center[i],x,shape)
+	   g <- attr(tmp,"gradient")
+	   df_a[,i] <- g[,1];
+	   df_b[,i] <- g[,2];
+	   df_center[,i] <- g[,3];
+	j_f <- tmp
+# 2nd derivative
+test_D2_fcn_L2 <- function(par,n,x,y_and_noise,fcall) {
+	shape = 8.6
+	a <- par[1:n]
+	f <- do.call("fcall",c(list(a = a), list(b = b), list(center = center), list(n = n), list(x = x))) - y_and_noise
+	for (i in 1:n) {
+	j_f <- tmp
+	term1 <- t(j_f) %*% j_f
+# 1st term in the equation calculated, shall be a 3n x 3n matrix
+	f_D2f = matrix(rep(c(0),9*n^2),ncol = 3*n,nrow = 3*n);
+	for (i in 1:n) {
+	   h <- colSums(attr(tmp,"hessian")*f,1)
+	   f_D2f[i,i] = h[1,1];
+	   f_D2f[n+i,i] = f_D2f[i,n+i] = h[1,2];
+	   f_D2f[2*n+i,i] = f_D2f[i,2*n+i] = h[1,3];
+	   f_D2f[n+i,n+i] = h[2,2];
+	   f_D2f[2*n+i,n+i] = f_D2f[n+i,2*n+i] = h[2,3];
+	   f_D2f[2*n+i,2*n+i] = h[3,3];
+	for (i in 1:(dim(f_D2f)[1]) ) {
+		for (j in 1:(dim(f_D2f)[2]) ) {
+			if (f_D2f[i,j] == "NaN") {f_D2f[i,j] = 0}
+	term1 + f_D2f
+# plot fitted curve with observed one
+plot.est <- function(par,fcall,n,x,col) {
+	a <- par[1:n]
+	y_est <- do.call("fcall",c( as.list(new_par), list(n = n), list(x = x) ))
+	lines(x,y_est,col = col,lwd = 2)
+# plot individual fitted curve
+plot.est.individual <- function(par,fcall,n,x,col) {
+	a <- par[1:n]
+	for (i in 1:n)
+	new_par <- c(list(a = a[i]),list(b = b[i]),list(center = center[i]))
+	y_est <- do.call("fcall",c( as.list(new_par), list(n = 1), list(x = x) ))
+	lines(x,y_est,col = col,lwd = 1)
+# fit summary
+# fit statistical summary for constraint estimation
+est.stats.summary <- function(par,sse,x,y) {
+	n_x = length(x); # the number of observations
+	m = length(par); # the number of parameters
+	sse # sum of squares due to error
+	ave_y = mean(y); # the mean of observation
+	ssm = 0.5* t(y - ave_y) %*% (y - ave_y); # the sum of square about mean
+	r2 = 1 - sse/ssm; # R square, coefficient of determination
+	dof = n_x - m; # degree of freedom
+	r2_adjusted = 1 - sse*(n_x-1)/(ssm*(dof-1)); # adjusted R square
+	mse = sse/dof; # the mean square error
+	se = sqrt(mse); # the standard error of fit, the root mse
+	msr = (ssm - sse)/(m - 1); # mean square regression
+	f = msr/mse; # F-statistics
+	c(r2,dof,r2_adjusted,f,se)
+#	c("r2" = r2,"DF" = dof,"Adj r2" = r2_adjusted,"F" = f,"standard error of fit" = se)
+# fit summary includes two fitting parameters (amplitude and centerfwhm and analytical area under the curve
+# -----fwhm------------
+# fwhm ~ 2.35*b^(1/2)*c
+# b & c are from gamma variate function x^b*exp(-t/c)
+# this approximation is found in ref "Event-related fMRI Contast When using Constant Interstimulus Interval: Theory and Experiment", pubished in Magnetic Resonance in Medicine 43:540-548 (2000)
+# this approximation result is a little bit different from that from peakfit
+# in our code,shape parameter is fixed at 8.6 & width related parameter is b
+# fwhm ~ 2.35*sqrt(8.6)/b
+# -----area under the curve-------
+# after some derivations, area under the curve is a/b*exp(8.6)*8.6^(-8.6)*gamma(8.6+1);
+# the derivation was confirmed with peakfit result
+est.summary_1 <- function(fcall,par,sse,n,x,y) {
+	a <- par[1:n] # estimated a
+	b <- par[(n+1):(2*n)] # estimated b
+	center <- par[(2*n+1):(3*n)] # estimated center
+# --calculate standard error of fit
+#---standard error of parameters, se * 1/sqrt(diag(hessian matrix of 0.5*|y-y_hat|^2))
+	std_par <- se *	1/sqrt(diag(test_D2_fcn_L2(par,n,x,y,f))) # std error of estimated parameters
+	std_a <- std_par[1:n];
+	std_b <- std_par[(n+1):(2*n)];
+	std_center <- std_par[(2*n+1):(3*n)];
+#---calculate fwhm, analytical area and percent area------
+	shape <- 8.6
+	fwhm <- matrix(c(0),ncol = 1,nrow = n);
+	area <- matrix(c(0),ncol = 1,nrow = n);
+	percent_area <- matrix(c(0),ncol = 1,nrow = n);	for (i in 1:n) {
+		fwhm[i] <- 2.35*sqrt(shape)/b[i];
+		area[i] <- a[i]/b[i]*exp(shape)*shape^(-shape)*gamma(shape+1);
+    percent_area <- area/sum(area)*100;
+#---need to double check---------------------
+	std_fwhm <- std_b * 2.35*sqrt(8.6) * 1/sqrt(b^4);
+#---calculate partial F stats for each peak
+	y_est_col <- matrix(c(0),ncol = n, nrow = n_x);
+	for (i in 1:n)
+	new_par <- c(list(a = a[i]),list(b = b[i]),list(center = center[i]));
+	y_est_col[,i] <- do.call("fcall",c( as.list(new_par), list(n = 1), list(x = x) )); # each col corresponds to each peak fitted ts
+	p_partial <- matrix(c(0),ncol = 1, nrow = n);
+	for (i in 1:n)
+	res_wo_i <- rowSums(y_est_col[,-i]) - y; # residual without ith peak
+	ssr <- 0.5*res_wo_i %*% res_wo_i; # sum square of error of residual
+	dof_diff <- 3; # degree of freedom difference between full model and reduced model (i.e. without ith peak)
+	F_partial <- ((ssr - sse)/dof_diff)/(sse/dof); # partial F stats for ith peak
+	p_partial[i] <- 1 - pf(F_partial,dof_diff,dof);
+#---summary of individual results
+	summary <- data.frame(a,std_a,center,std_center,fwhm,std_fwhm,area,percent_area,p_partial);
+	name_of_row <- paste("Peak",1:n,sep="");
+	name_of_col <- c("Amplitude","e_Amplitude","Center","e_Center","FWHM","e_FWHM","Area","% Area","p_partial");
+	dimnames(summary) <- list(name_of_row,name_of_col);
+	summary
+est.summary <- function(par,sse,n,x,y) {
+	shape <- 8.6
+    percent_area <- area/sum(area, na.rm=T)*100;
+#---onset ---------------
+	onset <- center - shape/b;
+	summary <- data.frame(a,std_a,center,std_center,fwhm,std_fwhm,area,percent_area,onset);
+	name_of_col <- c("Amplitude","e_Amplitude","Center","e_Center","FWHM","e_FWHM","Area","% Area","onset");
+	summary
Property changes on: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/peakfitv2v1.R
___________________________________________________________________
Added: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/preprocessEnewsmooth.R
--- SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/preprocessEnewsmooth.R	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/preprocessEnewsmooth.R	2009-08-06 16:03:58 UTC (rev 3070)
@@ -0,0 +1,76 @@
+preprocess_1 <- function(input) {
+		# read file (read.table) and save as vector (as.matrix)
+			original_y <- input*1000;
+		# original # of points before interpolation
+			original_x <- c(1:length(original_y));
+		#---------calculate 2nd derivative to find peaks------------------------------------
+		# windowlength argument n
+		# p is order of polynimal
+		# D is the order of derivative
+			windowlength <- 3 # 3 data points covered
+		# tested 4 data points, detail info might be lost
+			order_polynomial <- 2; # includes constant, linear and quadratic terms
+			order_derivative <- 2; # need the information of second derivatives
+			derivative_original_y <- sav.gol(original_y, fl = windowlength, forder = order_polynomial, dorder = order_derivative);
+		# guess # of possible peaks by counting negative y derivatives and corresponding amplitude of y > noise level
+			noise_level <- 0; # so far noise level is set to 0
+		# guess peak location: use all negative second derivatives or use local min of second derivative
+		# peak_location = original_x[derivative_original_y < 0 & original_y > noise_level];
+			tmp <- rep(c(0),length(original_x));
+			for ( i in 2:(length(original_x)-1) )  {
+				if ( (derivative_original_y[i] < derivative_original_y[i-1]) & (derivative_original_y[i] < derivative_original_y[i+1]) )
+				{ tmp[i] = i;}
+			peak_location = original_x[tmp > 0];
+			possible_peaks = length(peak_location)
+		#-----------------interpolation data---------------------------------------------------
+		# always needs # of parameters < length of observation
+		# in the case that 2nd derivative detect many peaks, interpolation shall be used
+			stim_res = 2 # sympliy double the time points
+			interpolation <- ksmooth(original_x,original_y,"normal",bandwidth = 1,x.points = seq(1,length(original_x),by = 1/stim_res));
+		#derivative_interpolation <- sav.gol(interpolation$y, fl = windowlength, forder = order_polynomial, dorder = order_derivative);
+		# calculatae new peak location
+			new_peak_location = stim_res*(peak_location - 1) + 1;
+		# calculatae new peak amplitude
+			peak_amplitude = rep(c(0),possible_peaks);
+			for (i in 1:possible_peaks ) { peak_amplitude[i] = interpolation$y[new_peak_location[i]] }
+		#--------------------initializaation----------------------------------------
+		# parameter a corresponds to peak amplitude
+			a_guess <- peak_amplitude;
+		# parameter b corresponds to 1/peak width
+			b_guess <- rep(c(length(original_y)/possible_peaks), possible_peaks);
+		#real_center_guess <- interpolation$x[new_peak_location];
+		#center_guess <- b_guess*real_center_guess;
+			center_guess <- interpolation$x[new_peak_location];
+			guess <- c(a_guess,b_guess,center_guess);
+			n <- possible_peaks;
+			out <- list(guess = guess,n = n,interpolated_x = interpolation$x,interpolated_y = interpolation$y);
+			out
\ No newline at end of file
Property changes on: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/preprocessEnewsmooth.R
Added: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/subqrymediator.R
--- SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/subqrymediator.R	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/Rscripts/subqrymediator.R	2009-08-06 16:03:58 UTC (rev 3070)
@@ -0,0 +1,64 @@
+library(stats)
+source("Rscripts/preprocessEnewsmooth.R")
+source("Rscripts/peakfitv2v1.R")
+inputfilename <- Sys.getenv("R_INPUT")
+print(inputfilename)
+allargs <- Sys.getenv("R_SWIFT_ARGS")
+print(allargs)
+outobjectname <- noquote(strsplit(allargs," ")[[1]][2])
+print(outobjectname)
+outputPDFfilename <- paste(outobjectname,"pdf",sep="")
+outputAfilename <- paste(outobjectname,"a",sep="")
+outputBfilename <- paste(outobjectname,"b",sep="")
+dd <- as.matrix(read.table(inputfilename))
+dd <- data.frame(dd[1,])
+print(length(dd[,1]))
+## taking the mean of the TS to be the baseline
+quickbase <- mean(dd[,1])
+adjusted.input = dd[,1]-quickbase
+print(paste("starting res_preprocess ::: ",date(),sep=""))
+res_preprocess <- preprocess_1(input = adjusted.input);
+print(paste("moving on to test_nlminb ::: ",date(),sep=""))
+test2_res_D2_nlminb <- nlminb(
+        start = res_preprocess$guess,
+        objective = fcn_L2,
+        gradient = test_D_fcn_L2,
+#hessian = test_D2_fcn_L2,
+        control = list(eval.max = 50000, iter.max = 5000),
+# the lower line with fewer iterations is just for testing purposes. the upper line is the real one
+# control = list(eval.max = 100, iter.max = 50),
+        lower = rep(c(0),length(res_preprocess$guess)),
+        fcall = f,
+        n = res_preprocess$n,
+        x = res_preprocess$interpolated_x,
+        y_and_noise = res_preprocess$interpolated_y)
+pdf(file=outputPDFfilename)
+op <- par(mfrow=c(1,1))
+plot(res_preprocess$interpolated_x,res_preprocess$interpolated_y,xlab = "",ylab = "BOLD (1E-3)",type = "b");
+plot.est(par = test2_res_D2_nlminb$par, fcall = f, n = res_preprocess$n, res_preprocess$interpolated_x,col = "blue");
+plot.est.individual(par = test2_res_D2_nlminb$par, fcall = f, n = res_preprocess$n, res_preprocess$interpolated_x,col = "blue");
+dev.off()
+par(op)
+result1<- est.stats.summary(
+        par = test2_res_D2_nlminb$par,
+        sse = test2_res_D2_nlminb$objective,
+        y = res_preprocess$interpolated_y)
+result2 <- est.summary(
+write.table(result1,outputAfilename,row.name = F,col.name = F)
+write.table(result2,outputBfilename,row.name = F,col.name = F)
