[Swift-commit] r3068 - SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain
Thu Aug 6 11:02:07 CDT 2009
Author: andric
Date: 2009-08-06 11:02:07 -0500 (Thu, 06 Aug 2009)
New Revision: 3068
Added:
   SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/ts_mediator.swift
Log:
now using a 'SUBQUERY' arg in Mediator that can more easily specify columns rather than using the wildcard
Added: SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/ts_mediator.swift
--- SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/ts_mediator.swift	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/peakfit_pilots/PK2/wholebrain/ts_mediator.swift	2009-08-06 16:02:07 UTC (rev 3068)
@@ -0,0 +1,58 @@
+#--- peak analysis across the brain via Mediator
+## type declarations:
+type file{}
+type Rscript;
+## a type for simple mapping the 3 R scripts used:
+type PeakfitR{
+    Rscript subqrymediator;
+    Rscript preprocessEnewsmooth;
+    Rscript peakfitv2v1;
+## a type for simple mapping the two output files:
+type PeakResult{
+    file pdf;
+    file a;
+    file b;
+## Mediator app declaration:
+app (file q_result, PeakResult outObj) run_query (string med_args, file config, PeakfitR code){
+    Mediator med_args stdout=@filename(q_result) @filename(code.subqrymediator);
+## this process sets parameters and calls Mediator:
+loop_query(int vert, string user, string db, string host, string query_outline, PeakfitR code, file config, string subject, string h, int beginTS, int endTS){
+    string theoutprefix = "FAH_Q";
+    PeakResult outObj<simple_mapper; location="results", prefix=@strcat(subject,"_",h,"vert",vert,".result.")>;
+    file q_result <single_file_mapper; file=@strcat("Qresults/",subject,"_",h,"vert",vert,".qresult")>;
+    string med_args = @strcat("--user ","andric"," --conf ", @filename(config)," --db ", db," --host ", host,
+        " --vox ", vert," --subject ", subject," --subquery tsTSVAR"," --begin_ts ",beginTS," --end_ts ",endTS,
+        " --query ", query_outline," --r_swift_args ", @filename(outObj)," --outprefix ", theoutprefix, " --r_script ", at filename(code.subqrymediator));
+    trace(med_args);
+    (q_result, outObj) = run_query(med_args, config, code);
+## needed parameters to use Mediator:
+string user = @arg("user");
+string db = "HEL";
+string host = "tp-neurodb.ci.uchicago.edu";
+file config<single_file_mapper; file="user.config">;
+## mapping the R code:
+PeakfitR code<simple_mapper; location="Rscripts", suffix=".R">;
+## variables to move across in the foreach loops:
+string declarelist[] = ["PK2smth"];
+string hemilist[] = ["lh"];
+int vertices[] = [3];
+foreach subject in declarelist{
+    foreach h in hemilist{
+        int beginTS = 0;
+        int endTS = 1807;
+        string query_outline = @strcat("SELECT SUBQUERY FROM peakTS_data",h," WHERE subject = '",subject,"' AND vertex=VOX");
+        foreach vert in vertices{
+            loop_query(vert, user, db, host, query_outline, code, config, subject, h, beginTS, endTS);
