[Swift-commit] r3053 - SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs
Thu Aug 6 10:26:49 CDT 2009
Author: andric
Date: 2009-08-06 10:26:49 -0500 (Thu, 06 Aug 2009)
New Revision: 3053
Added:
   SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/indiv_ccfinterp.swift
Log:
does ccf on individual subjs using interpolation
Added: SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/indiv_ccfinterp.swift
--- SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/indiv_ccfinterp.swift	                        (rev 0)
+++ SwiftApps/SIDGrid/swift/projects/andric/ccf_emblem/individual_ss/interpolatedHRFs/indiv_ccfinterp.swift	2009-08-06 15:26:49 UTC (rev 3053)
@@ -0,0 +1,53 @@
+#-- doing this analysis this time interpolating the HRFs for better lag precision
+type file{}
+app (file qout, file rout) run_query (string allcatargs, file config, file dot_r){
+    Mediator allcatargs stdout=@filename(qout) @filename(dot_r);
+loop_query(int bvox, string user, string db, string host, string query_outline, file r_script, file config, string id, string h, int ss){
+    int evox = bvox+3999;
+    string r_swift_args = h;
+    string theoutprefix = @strcat("ss",ss,"interp_results/",id,bvox,"_",evox);
+    string med_args = @strcat("--user ","andric",
+            " --conf ", "user.config",
+            " --db ", db,
+            " --host ", host,
+            " --query ", query_outline,
+            " --r_script ", @filename(r_script),
+            " --begin_vox ", bvox,
+            " --end_vox ", evox,
+            " --subject ", id,
+            " --batchstep ", "1000",
+            " --outprefix ", theoutprefix,
+            " --r_swift_args ", r_swift_args,
+            " --subject ", id);
+    file q_result <single_file_mapper; file=@strcat("Qresults/ss",ss,"_",id,bvox,"_",evox,".qresult")>;
+    file r_result <single_file_mapper; file=@strcat(theoutprefix,".tar")>;
+    (q_result, r_result) = run_query(med_args, r_script, config);
+string user = @arg("user");
+string db = "EMBLEM1";
+string host = "tp-neurodb.ci.uchicago.edu";
+file r_script<single_file_mapper; file="scripts/indiv_ccfinterp.R">;
+file config<single_file_mapper; file="user.config">;
+int subjs[] = [3,5,6,7,8,10,11,12,13,14,15,17,18,19,20,21,22,23,24,25,26,27,28,30];
+#int subjs[] = [3];
+int mybatches[] = [1:196000:4000];
+string hemis[] = ["lh","rh"];
+string nombre = "interp";
+foreach ss in subjs{
+    foreach h in hemis {
+        string query_outline = @strcat("SELECT subject, voxel, speech0B, speech1B, speech2B, speech3B, speech4B, speech5B, speech6B, speech7B, speech8B, gesture0B, gesture1B, gesture2B, gesture3B, gesture4B, gesture5B, gesture6B, gesture7B, gesture8B, gestspeech0B, gestspeech1B, gestspeech2B, gestspeech3B, gestspeech4B, gestspeech5B, gestspeech6B, gestspeech7B, gestspeech8B, grasp0B, grasp1B, grasp2B, grasp3B, grasp4B, grasp5B, grasp6B, grasp7B, grasp8B FROM emblemfem",h," WHERE subject = ",ss," AND voxel between BEGIN_BATCH and END_BATCH");
+        string id = @strcat(nombre,"_",h);
+        foreach batch in mybatches {
+            loop_query(batch, user, db, host, query_outline, r_script, config, id, h, ss);
