[Swift-commit] r2865 - SwiftApps/pc3
Tue Apr 21 09:06:00 CDT 2009
Author: benc
Date: 2009-04-21 09:06:00 -0500 (Tue, 21 Apr 2009)
New Revision: 2865
Modified:
   SwiftApps/pc3/pc3.swift
Log:
make pc3.swift more swiftier
Modified: SwiftApps/pc3/pc3.swift
--- SwiftApps/pc3/pc3.swift	2009-04-21 07:54:04 UTC (rev 2864)
+++ SwiftApps/pc3/pc3.swift	2009-04-21 14:06:00 UTC (rev 2865)
@@ -1,6 +1,9 @@
 type xmlfile;
 type textfile;
+(external out) checkvalid(boolean b) {
+  if(!b) { stop(); }
 (xmlfile output) ps_load_executable(xmlfile input, string s) {
   app {
@@ -8,6 +11,13 @@
+(xmlfile output) ps_load_executable_threaded(xmlfile input, string s, external thread) {
+  app {
+    ps_load_executable_app @input s @output;
 (textfile output) parse_xml_boolean_value(xmlfile input) {
   app {
     parse_xml_boolean_value_app @input @output;
@@ -36,7 +46,8 @@
   output = ps_load_executable_boolean(input, "IsMatchCSVFileTables");
-(xmlfile output) create_empty_load_db(xmlfile input) {
+// TODO I think this output never gets used?
+(xmlfile output, external outthread) create_empty_load_db(xmlfile input) {
   output = ps_load_executable(input, "CreateEmptyLoadDB");
@@ -56,42 +67,43 @@
   output = ps_load_executable_boolean(input, "IsExistsCSVFile");
-(xmlfile output) read_csv_file_column_names(xmlfile input) {
-  output = ps_load_executable(input, "ReadCSVFileColumnNames");
+(xmlfile output) read_csv_file_column_names(xmlfile input, external thread) {
+  output = ps_load_executable_threaded(input, "ReadCSVFileColumnNames", thread);
 (boolean output) is_match_csv_file_column_names(xmlfile input) {
   output =  ps_load_executable_boolean(input, "IsMatchCSVFileColumnNames");
-(xmlfile output) ps_load_executable_db (xmlfile db, xmlfile input, string s) {
+(xmlfile output) ps_load_executable_db (xmlfile db, xmlfile input, string s, external thread) {
   app {
     ps_load_executable_db_app @db @input s @output;
-(boolean output) ps_load_executable_db_boolean(xmlfile db, xmlfile input, string s) {
-  xmlfile xml_out = ps_load_executable_db(db, input, s);
+(boolean output) ps_load_executable_db_boolean(xmlfile db, xmlfile input, string s, external thread) {
+  xmlfile xml_out = ps_load_executable_db(db, input, s, thread);
   output = extract_boolean(xml_out);
-(boolean output) load_csv_file_into_table(xmlfile db, xmlfile input) {
-  output = ps_load_executable_db_boolean(db, input, "LoadCSVFileIntoTable");
+(boolean output) load_csv_file_into_table(xmlfile db, xmlfile input, external thread) {
+  output = ps_load_executable_db_boolean(db, input, "LoadCSVFileIntoTable", thread);
-(boolean output) update_computed_columns(xmlfile db, xmlfile input) {
-  output = ps_load_executable_db_boolean(db, input, "UpdateComputedColumns");
+(boolean output) update_computed_columns(xmlfile db, xmlfile input, external thread) {
+  output = ps_load_executable_db_boolean(db, input, "UpdateComputedColumns", thread);
-(boolean output) is_match_table_row_count(xmlfile db, xmlfile input) {
-  output = ps_load_executable_db_boolean(db, input, "IsMatchTableRowCount");
+(boolean output) is_match_table_row_count(xmlfile db, xmlfile input, external thread) {
+  output = ps_load_executable_db_boolean(db, input, "IsMatchTableRowCount", thread);
-(boolean output) is_match_table_column_ranges(xmlfile db, xmlfile input) {
-  output = ps_load_executable_db_boolean(db, input, "IsMatchTableColumnRanges");
+(boolean output) is_match_table_column_ranges(xmlfile db, xmlfile input, external thread) {
+  output = ps_load_executable_db_boolean(db, input, "IsMatchTableColumnRanges", thread);
-compact_database (xmlfile input) {
+// TODO what is the input used for here?
+compact_database (xmlfile input, external thread) {
   app {
     compact_database_app @input;
@@ -116,11 +128,12 @@
 is_csv_ready_file_exists_output = is_csv_ready_file_exists(csv_root_path_input);
-if(is_csv_ready_file_exists_output) {
   read_csv_ready_file_output = read_csv_ready_file(csv_root_path_input);
   is_match_csv_file_tables_output = is_match_csv_file_tables(read_csv_ready_file_output);
   if(is_match_csv_file_tables_output) {
-    create_empty_load_db_output = create_empty_load_db(job_id);
+    external db_over_time[];
+    external dbinit; // some bug in analysis means can't use db_over_time for initial one
+    (create_empty_load_db_output, dbinit) = create_empty_load_db(job_id);
     count_entries_output = count_entries(read_csv_ready_file_output);
     entries = readData(count_entries_output);
     int entries_seq[] = [1:entries];
@@ -128,9 +141,11 @@
     foreach i in entries_seq {
       split_list_output[i] = extract_entry(read_csv_ready_file_output, i);
-    iterate i {
+// TODO this can merge with merge with above foreach
+    foreach i in entries_seq {
       boolean is_exists_csv_file_output;
       xmlfile read_csv_file_column_names_output;
       boolean is_match_csv_file_column_names_output;
@@ -139,48 +154,27 @@
       boolean is_match_table_row_count_output;
       boolean is_match_table_column_ranges_output;
-      is_exists_csv_file_output = is_exists_csv_file(split_list_output[i+1]);
-      if(is_exists_csv_file_output) {
-	read_csv_file_column_names_output = read_csv_file_column_names(split_list_output[i+1]);
-	is_match_csv_file_column_names_output = is_match_csv_file_column_names(read_csv_file_column_names_output);
-	if(is_match_csv_file_column_names_output) {
-	  load_csv_file_into_table_output = load_csv_file_into_table(create_empty_load_db_output, read_csv_file_column_names_output);
-	  if(load_csv_file_into_table_output) {
-	    update_computed_columns_output = update_computed_columns(create_empty_load_db_output, read_csv_file_column_names_output);
-	    if(update_computed_columns_output) {
-	      is_match_table_row_count_output = is_match_table_row_count(create_empty_load_db_output, read_csv_file_column_names_output);
-	      if(is_match_table_row_count_output) {
-		is_match_table_column_ranges_output = is_match_table_column_ranges(create_empty_load_db_output, read_csv_file_column_names_output);
-		if(!is_match_table_column_ranges_output) {
-		  stop();
-	      else {
-		stop();
-	    else {
-	      stop();
-	  else {
-	    stop();
-	else {
-	  stop();
+      is_exists_csv_file_output = is_exists_csv_file(split_list_output[i]);
+      external thread6 = checkvalid(is_exists_csv_file_output);
+read_csv_file_column_names_output = read_csv_file_column_names(split_list_output[i], thread6);
+      is_match_csv_file_column_names_output = is_match_csv_file_column_names(read_csv_file_column_names_output);
+      external thread2 = checkvalid(is_match_csv_file_column_names_output);
+      if(i==1) { // first element...
+        load_csv_file_into_table_output = load_csv_file_into_table(create_empty_load_db_output, read_csv_file_column_names_output, dbinit);
+      } else {
+	     load_csv_file_into_table_output = load_csv_file_into_table(create_empty_load_db_output, read_csv_file_column_names_output, db_over_time[i]);
-      else {
-	stop();
-    } until ((i + 2) > entries);
-    compact_database(create_empty_load_db_output);
+      external thread3=checkvalid(load_csv_file_into_table_output);
+      update_computed_columns_output = update_computed_columns(create_empty_load_db_output, read_csv_file_column_names_output, thread3);
+      external thread4 = checkvalid(update_computed_columns_output);
+      is_match_table_row_count_output = is_match_table_row_count(create_empty_load_db_output, read_csv_file_column_names_output, thread4);
+      external thread1 = checkvalid(is_match_table_row_count_output);
+      is_match_table_column_ranges_output = is_match_table_column_ranges(create_empty_load_db_output, read_csv_file_column_names_output, thread1);
+      db_over_time[i+1] = checkvalid(is_match_table_column_ranges_output);
+    compact_database(create_empty_load_db_output, db_over_time[entries+1]);
   else {
     stop();
-else {
-   stop();
