[Swift-commit] r2851 - usertools/cio/bin
Thu Apr 9 14:29:45 CDT 2009
Author: aespinosa
Date: 2009-04-09 14:29:44 -0500 (Thu, 09 Apr 2009)
New Revision: 2851
Added:
   usertools/cio/bin/falkon_vanilla.sh
   usertools/cio/bin/gentcdata
   usertools/cio/bin/swift_bgp.sh
Modified:
   usertools/cio/bin/ciologic-bgp.sh
Log:
Swift wrapper for the bluegene
Modified: usertools/cio/bin/ciologic-bgp.sh
--- usertools/cio/bin/ciologic-bgp.sh	2009-04-09 19:29:16 UTC (rev 2850)
+++ usertools/cio/bin/ciologic-bgp.sh	2009-04-09 19:29:44 UTC (rev 2851)
@@ -134,8 +134,9 @@
 #Core MTIO logic
 if [ $DHT -eq 0 ]; then
-    $CIOROOT/libexec/hashserver.rb
-else [ $RANK -eq $IFS_RANK ]; then
+    RUBY=/home/espinosa/local/bin/ruby
+    $RUBY $CIOROOT/libexec/hashserver.rb
+elif [ $RANK -eq $IFS_RANK ]; then
     ifs_head $STRIPE_SIZE
     /home/zzhang/cio/bin/collector.sh
 elif [ $RANK -lt $IFS_SLAVE ]; then
Copied: usertools/cio/bin/falkon_vanilla.sh (from rev 2835, usertools/cio/bin/falkon-start.sh)
--- usertools/cio/bin/falkon_vanilla.sh	                        (rev 0)
+++ usertools/cio/bin/falkon_vanilla.sh	2009-04-09 19:29:44 UTC (rev 2851)
@@ -0,0 +1,15 @@
+#!/bin/bash
+if [ -z $CIOROOT ]; then
+  echo "ERROR: CIOROOT env not defined"
+  exit 1
+fi
+if [ -z $CIOARCH ]; then
+  echo "ERROR: CIOARCH not defined"
+  exit 1
+fi
+if [ -z $CHIRPROOT ]; then
+  echo "ERROR: CHIRPROOT not defined"
+  exit 1
+fi
+$CIOROOT/libexec/falkon/falkon_vanilla-$CIOARCH.sh $@
Added: usertools/cio/bin/gentcdata
--- usertools/cio/bin/gentcdata	                        (rev 0)
+++ usertools/cio/bin/gentcdata	2009-04-09 19:29:44 UTC (rev 2851)
@@ -0,0 +1,13 @@
+#!/bin/sh
+awk -v count=$1 '
+/@BGP@/ {
+  for (i=0;i<count;i++) {
+    line=$0
+    n=sprintf("BGP_%.3d",i);
+    sub(/@BGP@/,n,line);
+    print line
Property changes on: usertools/cio/bin/gentcdata
___________________________________________________________________
Added: usertools/cio/bin/swift_bgp.sh
--- usertools/cio/bin/swift_bgp.sh	                        (rev 0)
+++ usertools/cio/bin/swift_bgp.sh	2009-04-09 19:29:44 UTC (rev 2851)
@@ -0,0 +1,58 @@
+#!/bin/bash
+if [ -z "$3" ]; then
+  echo "usage: $0 <FALKON_ID> <NUM_NODES> <swift_script>"
+  exit 1
+fi
+CUR_DIR=`pwd`
+FALKON_JOB_ID=$1
+NUM_NODES=$2
+SWIFT_SCRIPT=$3
+SERVICE_LIST_FILE=/home/falkon/users/${USER}/${FALKON_JOB_ID}/config/Client-service-URIs.config
+let NUM_ION=NUM_NODES/64
+echo "waiting for at least ${NUM_NODES} nodes to register before submitting workload..."
+falkon-wait-for-allocation.sh ${SERVICE_LIST_FILE} ${NUM_ION}
+echo "found at least ${NUM_NODES} registered, submitting workload..."
+workdir=`pwd`/work
+# Base entry for localhost
+cat >sites.xml <<END
+<config>
+END
+# Create one entry per falkon server (i.e. one per pset)
+let s=0
+tail +2 $SERVICE_LIST_FILE |
+while read ip port; do
+  server=`echo $s | awk '{printf "%.3d", $1}'`
+  cat >>sites.xml <<END
+  <pool handle="BGP_$server">
+    <execution provider="deef" url="http://$ip:50001/wsrf/services/GenericPortal/core/WS/GPFactoryService"/>
+    <gridftp url="local://localhost"/>
+    <workdirectory>$workdir</workdirectory>
+    <profile namespace="karajan" key="jobThrottle">8</profile>
+    <profile namespace="karajan" key="initialScore">1000</profile>
+  </pool>
+END
+  let s=$s+1
+done
+echo "</config>" >> sites.xml
+shift 2   # leave $3 and following - swift script and args
+if [ ! -f ./tc.data ]; then
+  echo "ERROR: tc.data not found"
+  exit 1
+fi
+swift </dev/null -sites.file ./sites.xml -tc.file ./tc.data $*
Property changes on: usertools/cio/bin/swift_bgp.sh
