[Swift-commit] r2845 - trunk/docs
Wed Apr 8 07:29:40 CDT 2009
Author: benc
Date: 2009-04-08 07:29:35 -0500 (Wed, 08 Apr 2009)
New Revision: 2845
Modified:
   trunk/docs/userguide.xml
Log:
doc that ip.address is deprecated (as indicated in swift.properties)
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-04-08 12:28:46 UTC (rev 2844)
+++ trunk/docs/userguide.xml	2009-04-08 12:29:35 UTC (rev 2845)
@@ -2361,7 +2361,6 @@
 							</para>
 							<para>
 								The Globus GRAM service uses a callback
 								mechanism to send notifications about the status
 								of submitted jobs. The callback mechanism
@@ -2375,8 +2374,11 @@
 								address of the Swift client machine can be
 								specified using this property. The value of this
 								property must be a numeric address without quotes.
 							</para>
+							<para>
+								This option is deprecated and the hostname
+								property should be used instead.
+							</para>
 						</listitem>
 					</varlistentry>
