[Swift-commit] r2843 - trunk/docs
Wed Apr 8 07:28:00 CDT 2009
Author: benc
Date: 2009-04-08 07:27:56 -0500 (Wed, 08 Apr 2009)
New Revision: 2843
Modified:
   trunk/docs/userguide.xml
Log:
userguide doc for foreach.max.threads
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-04-08 12:27:07 UTC (rev 2842)
+++ trunk/docs/userguide.xml	2009-04-08 12:27:56 UTC (rev 2843)
@@ -2326,6 +2326,26 @@
 						</listitem>
 					</varlistentry>
+					<varlistentry id="property.foreach.max.threads">
+						<term>foreach.max.threads</term>
+						<listitem>
+							<para>
+								Valid values: positive integers
+							</para>
+							<para>
+								Default value: 1024
+							</para>
+							<para>
+Limits the number of concurrent iterations that each foreach statement
+can have at one time. This conserves memory for swift programs that
+have large numbers of iterations (which would otherwise all be executed
+in parallel). (since Swift 0.9)
+							</para>
+						</listitem>
+					</varlistentry>
 					<varlistentry>
 						<term>
 							<property>ip.address</property>
