[Swift-commit] r2837 - trunk/docs
Tue Apr 7 08:03:02 CDT 2009
Author: wilde
Date: 2009-04-07 08:03:00 -0500 (Tue, 07 Apr 2009)
New Revision: 2837
Modified:
   trunk/docs/userguide.xml
Log:
Added link to coaster design description page.
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2009-04-06 21:58:20 UTC (rev 2836)
+++ trunk/docs/userguide.xml	2009-04-07 13:03:00 UTC (rev 2837)
@@ -3473,7 +3473,10 @@
 The coaster mechanism submits a head job using some other execution
 mechanism such as GRAM, and for each worker node that will be used in
 a remote cluster, it submits a worker job, again using some other
-execution mechanism such as GRAM.
+execution mechanism such as GRAM. Details on the design of the coaster
+mechanism can be found
+<ulink url="http://http://wiki.cogkit.org/wiki/Coasters">
+here</ulink>
 </para>
 <para>
 The head job manages file transfers and the dispatch of execution jobs
