[Swift-commit] r2830 - nmi-build-test/submit-machine
Sun Apr 5 08:07:17 CDT 2009
Author: benc
Date: 2009-04-05 08:07:17 -0500 (Sun, 05 Apr 2009)
New Revision: 2830
Modified:
   nmi-build-test/submit-machine/build-hourly
   nmi-build-test/submit-machine/kickstart-hourly.tmp
   nmi-build-test/submit-machine/swift-hourly
   nmi-build-test/submit-machine/swift-hourly.tmp
Log:
incorrect variable name fixed on nmi-s005 long ago but not committed until now
Modified: nmi-build-test/submit-machine/build-hourly
--- nmi-build-test/submit-machine/build-hourly	2009-04-05 13:00:07 UTC (rev 2829)
+++ nmi-build-test/submit-machine/build-hourly	2009-04-05 13:07:17 UTC (rev 2830)
@@ -28,7 +28,7 @@
 if [ "X$KSREBUILD" != "X" ]; then
   cp kickstart.repo.latest kickstart.repo.last
   cp kickstart-hourly kickstart-hourly.tmp
-  echo "description = $REBUILD" >> kickstart-hourly.tmp
+  echo "description = $K5REBUILD" >> kickstart-hourly.tmp
   nmi_submit kickstart-hourly.tmp
 fi
Modified: nmi-build-test/submit-machine/kickstart-hourly.tmp
--- nmi-build-test/submit-machine/kickstart-hourly.tmp	2009-04-05 13:00:07 UTC (rev 2829)
+++ nmi-build-test/submit-machine/kickstart-hourly.tmp	2009-04-05 13:07:17 UTC (rev 2830)
@@ -16,4 +16,4 @@
 notify = benc at hawaga.org.uk
 remote_task_timeout = 12h
-description = Kickstart hourly:
+description =
Modified: nmi-build-test/submit-machine/swift-hourly
--- nmi-build-test/submit-machine/swift-hourly	2009-04-05 13:00:07 UTC (rev 2829)
+++ nmi-build-test/submit-machine/swift-hourly	2009-04-05 13:07:17 UTC (rev 2830)
@@ -1,7 +1,7 @@
 project = swift
 component = swift
 component_version = HEAD
-prereqs = apache-ant-1.7.0, java-1.4.2_05
+prereqs = apache-ant-1.6.2, java-1.5.0_08
 run_type = build
 inputs = coghead.svn, swifthead.svn, swiftnmi.svn
Modified: nmi-build-test/submit-machine/swift-hourly.tmp
--- nmi-build-test/submit-machine/swift-hourly.tmp	2009-04-05 13:00:07 UTC (rev 2829)
+++ nmi-build-test/submit-machine/swift-hourly.tmp	2009-04-05 13:07:17 UTC (rev 2830)
@@ -1,7 +1,7 @@
 project = swift
 component = swift
 run_type = build
@@ -10,9 +10,9 @@
 #platforms = x86_rhas_3, x86_cent_4.2, x86_rhas_4, x86_suse_10.0, x86_64_sles_9, x86_sl_4.4, ia64_sles_9, ia64_rhas_4, ppc_macos_10.3, x86_sles_8, x86_64_fc_4, x86_fc_2, x86_fc_3, ia64_sles_8, x86_rh_8.0, ia64_rhas_3, x86_deb_3.1, x86_rh_9, x86_64_rhas_3, x86_slf_3, x86_deb_4.0, x86_64_rhas_4, x86_64_deb_4.0, x86_fc_4, x86_slc_3, x86_rh_7.2, x86_ubuntu_5.10, x86_sles_9
-platforms = x86_deb_4.0
+platforms = x86_fc_5
-remote_task_timeout = 12h
-description = Swift >=r2011.
+remote_task_timeout = 720m
+description = Swift >=r2823.
