[Swift-commit] r2813 - trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui
Sat Apr 4 11:35:26 CDT 2009
Author: hategan
Date: 2009-04-04 11:35:25 -0500 (Sat, 04 Apr 2009)
New Revision: 2813
Modified:
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java
Log:
better cleanup and proper handling of tab key
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java	2009-04-04 16:06:23 UTC (rev 2812)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java	2009-04-04 16:35:25 UTC (rev 2813)
@@ -128,6 +128,11 @@
             terminal.initializeTerminal();
             os.write(ANSI.cursorVisible(false));
             os.flush();
+            Runtime.getRuntime().addShutdownHook(new Thread() {
+                public void run() {
+                    exit();
         catch (Exception e) {
             e.printStackTrace();
@@ -309,7 +314,12 @@
                 else if (c < 32 && c != 0x0a && c != 0x0d) {
-                    key = new Key(Key.MOD_CTRL, c + 96);
+                    if (c == 9) {
+                        key = new Key(Key.TAB);
+                    else {
+                        key = new Key(Key.MOD_CTRL, c + 96);
                 else if (c > 128) {
                     // XTerm
@@ -334,7 +344,7 @@
-                    //screen.status(key.toString());
+                    screen.status(key.toString());
@@ -360,6 +370,9 @@
                 screen.redraw();
             else {
+                if (done) {
+                    return 0;
                 try {
                     checkSize();
                     Thread.sleep(10);
@@ -534,6 +547,7 @@
     public void exit() {
+        done = true;
         try {
             os.write(ANSI.cursorVisible(true));
             os.flush();
@@ -541,7 +555,6 @@
-        done = true;
         screen = null;
         if (terminal instanceof UnixTerminal) {
             try {
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java	2009-04-04 16:06:23 UTC (rev 2812)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/Key.java	2009-04-04 16:35:25 UTC (rev 2813)
@@ -45,6 +45,7 @@
 	public static final int CR = 0x0d;
 	public static final int BACKSPACE = 0x7f;
 	public static final int ESC = 0x1b;
+	public static final int TAB = 0x09;
 	private static Map names;
@@ -80,6 +81,7 @@
 		putName(END, "END");
 		putName(INS, "INS");
 		putName(DEL, "DEL");
+		putName(TAB, "TAB");
 	private final int type;
