[Swift-commit] r2230 - in trunk/docs: . formatting
Fri Sep 19 11:35:20 CDT 2008
Author: benc
Date: 2008-09-19 11:35:19 -0500 (Fri, 19 Sep 2008)
New Revision: 2230
Added:
   trunk/docs/build-chunked-userguide.sh
   trunk/docs/formatting/swiftsh_html_chunked.xsl
Modified:
   trunk/docs/Makefile
   trunk/docs/buildguides.sh
Log:
Chunked userguide for easier online use
Modified: trunk/docs/Makefile
--- trunk/docs/Makefile	2008-09-19 15:20:30 UTC (rev 2229)
+++ trunk/docs/Makefile	2008-09-19 16:35:19 UTC (rev 2230)
@@ -6,6 +6,9 @@
 pdfs: userguide.pdf tutorial.pdf tutorial-live.pdf quickstartguide.pdf reallyquickstartguide.pdf languagespec.pdf languagespec-0.6.pdf log-processing.pdf
+chunked-userguide: userguide.xml
+	./build-chunked-userguide.sh
 %.php: %.xml
 	xsltproc --nonet formatting/swiftsh_html.xsl $<
 	sed -e "s/index.html#/#/g" index.html >$@
Added: trunk/docs/build-chunked-userguide.sh
--- trunk/docs/build-chunked-userguide.sh	                        (rev 0)
+++ trunk/docs/build-chunked-userguide.sh	2008-09-19 16:35:19 UTC (rev 2230)
@@ -0,0 +1,12 @@
+#!/bin/sh
+mkdir -p userguide/ || exit 1
+cd userguide/ || exit 2
+rm -f *.html *.php
+xsltproc --nonet ../formatting/swiftsh_html_chunked.xsl ../userguide.xml
+for a in *.html; do
+  B=$(basename -s .html $a)
+  mv $a ${B}.php
+done
Modified: trunk/docs/buildguides.sh
--- trunk/docs/buildguides.sh	2008-09-19 15:20:30 UTC (rev 2229)
+++ trunk/docs/buildguides.sh	2008-09-19 16:35:19 UTC (rev 2230)
@@ -32,3 +32,5 @@
 process "languagespec.xml" "swift_html.xsl"
 process "languagespec-0.6.xml" "swift_html.xsl"
 process "log-processing.xml" "swift_html.xsl"
+./build-chunked-userguide
Added: trunk/docs/formatting/swiftsh_html_chunked.xsl
--- trunk/docs/formatting/swiftsh_html_chunked.xsl	                        (rev 0)
+++ trunk/docs/formatting/swiftsh_html_chunked.xsl	2008-09-19 16:35:19 UTC (rev 2230)
@@ -0,0 +1,253 @@
+<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
+	<!-- Which DocBook standard xsl file should we use as the default? -->
+	<!-- Well, xsltproc doesn't cache the xsl files fetched over the web, so better use a local copy -->
+	<xsl:import href="docbook/html/chunk.xsl"/>
+	<xsl:param name="chunk.section.depth" select="1"></xsl:param>
+	<xsl:param name="use.id.as.filename" select="1"/>
+	<!--<xsl:import href="http://docbook.sourceforge.net/release/xsl/current/html/chunk.xsl"/>-->
+		testing: if you want to generate your own html without installing
+		stylesheets, substitute the following url for the import href above:
+		http://docbook.sourceforge.net/release/xsl/current/html/chunk.xsl
+	<!-- speed up the chunking process? -->
+	<xsl:param name="chunk.fast">1</xsl:param>
+		Use graphics in admonitions? like 'warnings' 'important' 'note' etc
+	<xsl:param name="admon.graphics">1</xsl:param>
+	<!-- Set path to admonition graphics  -->
+	<xsl:param name="admon.graphics.path">/docbook-images/</xsl:param>
+		Set path to docbook graphics (testing)
+        <xsl:param name="admon.graphics.path">file:///Z:/testing/alliance/docbook-images/</xsl:param>
+		Again, if 1 above, what is the filename extension for admon graphics?
+	<xsl:param name="admon.graphics.extension" select="'.gif'"/>
+	<!-- Set path to callout graphics -->
+	<xsl:param name="callout.graphics.path">/docbook-images/</xsl:param>
+	<!-- Depth to which sections should be chunked -->
+	<xsl:param name="chunk.section.depth">0</xsl:param>
+		Are parts automatically enumerated?
+		<xsl:param name="part.autolabel">0</xsl:param>
+	<!-- Are chapters automatically enumerated? -->
+	<xsl:param name="chapter.autolabel">0</xsl:param>
+	<!-- Are sections enumerated? -->
+	<xsl:param name="section.autolabel">1</xsl:param>
+	<!-- how deep should each toc be? (how many levels?) -->
+	<xsl:param name="toc.max.depth">2</xsl:param>
+		How deep should recursive sections appear in the TOC for chapters?
+	<xsl:param name="toc.section.depth">4</xsl:param>
+		Should the first section be chunked separately from its parent? > 0 = yes
+	<xsl:param name="chunk.first.sections">1</xsl:param>
+		Instead of using default filenames, use ids for filenames (dbhtml
+		directives take precedence) taking this out to avoid breaking any
+		current bookmarks
+                <xsl:param name="use.id.as.filename">1</xsl:param>
+	<!-- custom toc - book only shows chapter -->
+	<xsl:template match="preface|chapter|appendix|article" mode="toc">
+		<xsl:param name="toc-context" select="."/>
+		<xsl:choose>
+			<xsl:when test="local-name($toc-context) = 'book'">
+				<xsl:call-template name="subtoc">
+					<xsl:with-param name="toc-context" select="$toc-context"/>
+					<xsl:with-param name="nodes" select="foo"/>
+				</xsl:call-template>
+			</xsl:when>
+			<xsl:otherwise>
+					<xsl:with-param name="nodes" select="section|sect1|glossary|bibliography|index        |bridgehead[$bridgehead.in.toc != 0]"/>
+			</xsl:otherwise>
+		</xsl:choose>
+	</xsl:template>
+	<!-- INDEX PARAMETERS -->
+	<!-- do you want an index?  -->
+	<xsl:param name="generate.index">1</xsl:param>
+	<!-- Select indexterms based on type attribute value -->
+	<xsl:param name="index.on.type">1</xsl:param>
+	<!-- GLOSSARY PARAMETERS -->
+	<!-- Display glossentry acronyms? -->
+	<xsl:param name="glossentry.show.acronym">yes</xsl:param>
+		Name of the glossary collection file
+		<xsl:param name="glossary.collection" select="'glossary.xml'"></xsl:param>
+		Generate links from glossterm to glossentry automatically?
+		<xsl:param name="glossterm.auto.link">1</xsl:param>
+		if non-zero value for previous parameter, does automatic glossterm
+		linking only apply to firstterms?
+		<xsl:param name="firstterm.only.link">1</xsl:param>
+		permit wrapping of long lines of code
+		<xsl:attribute-set name="monospace.verbatim.properties"
+			use-attribute-sets="verbatim.properties monospace.properties">
+			<xsl:attribute name="wrap-option">wrap</xsl:attribute>
+		</xsl:attribute-set>
+	<!-- INCORPORATING DOCBOOK PAGES INTO WEBSITE -->
+		make sure there's a DOCTYPE in the html output (otherwise, some css renders strangely
+	<xsl:param name="chunker.output.doctype-public" select="'-//W3C//DTD HTML 4.01 Transitional//EN'"/>
+	<xsl:param name="chunker.output.doctype-system" select="'http://www.w3.org/TR/html4/loose.dtd'"/>
+	<!-- add elements to the HEAD tag -->
+	<xsl:template name="user.head.content">
+		<link href="http://www.ci.uchicago.edu/swift/css/style1col.css" rel="stylesheet" type="text/css"/>
+		<script type="text/javascript" src="http://www.ci.uchicago.edu/swift/dhtml.js"></script>
+		<script type="text/javascript" src="http://www.ci.uchicago.edu/swift/shCoreu.js"></script>
+		<script type="text/javascript" src="http://www.ci.uchicago.edu/swift/shBrushVDL2.js"></script>
+	</xsl:template>
+	<!-- add an attribute to the BODY tag -->
+	<xsl:template name="body.attributes">
+		<xsl:attribute name="class">section-3</xsl:attribute>
+	</xsl:template>
+		pull in 'website' with this code by modifying chunk-element-content from html/chunk-common.xsl
+	<xsl:template name="chunk-element-content">
+		<xsl:param name="prev"/>
+		<xsl:param name="next"/>
+		<xsl:param name="nav.context"/>
+		<xsl:param name="content">
+			<xsl:apply-imports/>
+		</xsl:param>
+		<xsl:call-template name="user.preroot"/>
+		<html>
+			<xsl:call-template name="html.head">
+				<xsl:with-param name="prev" select="$prev"/>
+				<xsl:with-param name="next" select="$next"/>
+			<body onLoad="initjs();sh();">
+				<xsl:call-template name="body.attributes"/>
+				<xsl:call-template name="user.header.navigation"/>
+				<xsl:call-template name="user.header.content"/>
+				<xsl:copy-of select="$content"/>
+				<xsl:call-template name="user.footer.content"/>
+				<xsl:call-template name="user.footer.navigation"/>
+			</body>
+		</html>
+	</xsl:template>
+		prevent h1 and h2 using clear: both - want to control in css, instead
+	<xsl:template name="section.heading">
+		<xsl:param name="section" select="."/>
+		<xsl:param name="level" select="'1'"/>
+		<xsl:param name="title"/>
+		<xsl:element name="h{$level+1}">
+			<xsl:attribute name="class">title</xsl:attribute>
+			<a>
+				<xsl:attribute name="name">
+					<xsl:call-template name="object.id">
+						<xsl:with-param name="object" select="$section"/>
+				</xsl:attribute>
+			</a>
+			<xsl:copy-of select="$title"/>
+		</xsl:element>
+	</xsl:template>
+	<xsl:template name="user.header.content">
+		<xsl:text disable-output-escaping="yes"><![CDATA[
+		<!-- entire page container -->
+		<div id="container">
+			<!-- header -->
+			<div id="header">
+				<?php require('../../inc/header.php') ?>
+			</div>
+			<!-- end header -->
+			<!-- nav -->
+			<div id="nav">
+				<?php require('../../inc/nav.php') ?>
+			</div>
+			<!-- end nav -->
+			<!-- content container -->
+			<div id="content">
+		</xsl:text>
+	</xsl:template>
+	<xsl:template name="user.footer.content">
+			</div>
+			<!-- end content container-->
+			<!-- footer -->
+			<div id="footer"><?php require('../../inc/footer.php') ?></div>
+			<!-- end footer -->
+		</div>
+		<!-- end entire page container -->
+		</xsl:text>
+	</xsl:template>
+</xsl:stylesheet>
