[Swift-commit] r2227 - trunk/docs
Wed Sep 17 14:42:42 CDT 2008
Author: benc
Date: 2008-09-17 14:42:41 -0500 (Wed, 17 Sep 2008)
New Revision: 2227
Modified:
   trunk/docs/userguide.xml
Log:
missing profile name for coastersPerNode
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2008-09-17 19:00:52 UTC (rev 2226)
+++ trunk/docs/userguide.xml	2008-09-17 19:42:41 UTC (rev 2227)
@@ -2291,7 +2291,7 @@
 			<para id="profile.globus.condor_requirements"><property>condor_requirements</property> allows a requirements string to be specified
 when Condor is used as an LRM behind GRAM2. Example: <profile namespace="globus" key="condor_requirements">Arch == "X86_64" || Arch="INTEL"</profile>
 			</para>
-			<para id="profile.globus.coastersPerNode">Specifies
+			<para id="profile.globus.coastersPerNode">coastersPerNode specifies
 the number of coaster workers to be run on each node. This profile entry
 is used by the coaster provider.
 			</para>
