[Swift-commit] r2218 - provenancedb
Fri Sep 5 09:52:00 CDT 2008
Author: benc
Date: 2008-09-05 09:51:57 -0500 (Fri, 05 Sep 2008)
New Revision: 2218
Modified:
   provenancedb/import-all
Log:
more information about how a log file is known
Modified: provenancedb/import-all
--- provenancedb/import-all	2008-09-05 14:35:23 UTC (rev 2217)
+++ provenancedb/import-all	2008-09-05 14:51:57 UTC (rev 2218)
@@ -3,7 +3,6 @@
 # we need to keep this out of the log-proceesing dir because import
 # of individual runs will clean other files.
-PROVDB=provdb
 source paths.source
@@ -33,15 +32,16 @@
 echo IMPORTING
 if grep --silent "DEBUG Loader Swift finished with no errors" $filename; then
-   $SQLCMD -c "INSERT INTO known_workflows (workflow_log_filename, version) VALUES ('$filename','$version');"
    echo version $version in log file $filename
      echo ============= will import =============
      ./prepare-for-import $filename
      ./import-run-to-sql $filename
      ./import-run-to-xml $filename
+     $SQLCMD -c "INSERT INTO known_workflows (workflow_log_filename, version, importstatus) VALUES ('$filename','$version','imported');"
    else
      echo SKIP: Workflow does not report successful end.
+     $SQLCMD -c "INSERT INTO known_workflows (workflow_log_filename, version, importstatus) VALUES ('$filename','$version','skipped - workflow did not end sucessfully');"
    fi
 else
 echo SKIP: Already known in workflow
