[Swift-commit] r2213 - provenancedb
Fri Sep 5 07:28:42 CDT 2008
Author: benc
Date: 2008-09-05 07:28:41 -0500 (Fri, 05 Sep 2008)
New Revision: 2213
Modified:
   provenancedb/import-all
   provenancedb/import-ci
Log:
PROVDB env variable to allow script to use different databases
Modified: provenancedb/import-all
--- provenancedb/import-all	2008-09-05 12:19:22 UTC (rev 2212)
+++ provenancedb/import-all	2008-09-05 12:28:41 UTC (rev 2213)
@@ -3,8 +3,10 @@
 # we need to keep this out of the log-proceesing dir because import
 # of individual runs will clean other files.
+PROVDB=provdb
 source paths.source
 pushd $LOGDIR
 ./create-everylog-vs-versions-data $LOGREPO
 popd
@@ -24,7 +26,7 @@
  if [ $version -ge 1538 ]; then
    echo -n "Log: $filename ... "
-EXISTING=$(psql -p 5435 -d provdb -U benc --tuples-only -c "select count(*) from known_workflows where workflow_log_filename='$filename';")
+EXISTING=$(psql -p 5435 -d $PROVDB -U benc --tuples-only -c "select count(*) from known_workflows where workflow_log_filename='$filename';")
 # echo EXISTING is X${EXISTING}X
 if [ $EXISTING -eq 0 ];  then
Modified: provenancedb/import-ci
--- provenancedb/import-ci	2008-09-05 12:19:22 UTC (rev 2212)
+++ provenancedb/import-ci	2008-09-05 12:28:41 UTC (rev 2213)
@@ -1,4 +1,12 @@
 #!/bin/bash
+if [ "X$PROVDB" == "X" ]; then
+  echo PROVDB is not set. Defaulting to provdb
+  export PROVDB=provdb
+else
+  echo PROVDB is set to $PROVDB
+fi
 cd /home/benc/swift-svn/provenancedb
 ./import-all $@
