[Swift-commit] r2309 - SwiftApps/adem-osg/bin
Mon Oct 20 21:19:07 CDT 2008
Author: houzx
Date: 2008-10-20 21:19:06 -0500 (Mon, 20 Oct 2008)
New Revision: 2309
Removed:
   SwiftApps/adem-osg/bin/auto-get-sites
Log:
sites
Deleted: SwiftApps/adem-osg/bin/auto-get-sites
--- SwiftApps/adem-osg/bin/auto-get-sites	2008-10-21 02:17:05 UTC (rev 2308)
+++ SwiftApps/adem-osg/bin/auto-get-sites	2008-10-21 02:19:06 UTC (rev 2309)
@@ -1,66 +0,0 @@
-#/bin/bash
-# To get the available grid sites
-if [ "X${ADEM_HOME}" = "X" ]; then
-    echo "You must set your ADEM_HOME variable! Then continue" 1>&2
-fi
-CDATE=`date +%F-%R`
-DIR="$ADEM_HOME"
-USER=`whoami`
-# get the grid computing sites
-GRID=$1
-VO=$2
-if [ "X$GRID" == "X" ]; then
-  echo "(1)Please input the GRID name as the first parameter, which can be:"
-  echo "osg osg-itb "
-  echo "(2)If necessary, please input the virtual organization name as the second parameter.Just use a space to separate the two parameters. For osg, vo can be:"
-  echo "CDF CMS CompBioGrid DES DOSAR DZero Engage Fermilab fMRI GADU geant4 GLOW GPN GRASE GridChem GridEx GROW i2u2 iVDGL LIGO mariachi MIS  nanoHUB NWICG  Ops  OSG OSGEDU SDSS STAR USATLAS"
-  exit
-fi
-/usr/bin/test -d $DIR/tmp
-  if [ $? -ne 0 ];then
-  /bin/mkdir $DIR/tmp
-  #else
-  #/bin/rm -i -r $DIR/tmp/*
-  fi
-  if [ "X$VO" == "X" ]; then
-  /usr/bin/wget -O $DIR/tmp/$GRID-sitelist.txt "http://vors.grid.iu.edu/cgi-bin/tindex.cgi?grid=$GRID" 1>/dev/null 2>/dev/null
-  else
-   /usr/bin/wget -O $DIR/tmp/$GRID-sitelist.txt "http://vors.grid.iu.edu/cgi-bin/tindex.cgi?grid=$GRID&VO=$VO" 1>/dev/null 2>/dev/null
- fi
-/bin/cat $DIR/tmp/$GRID-sitelist.txt |grep compute |grep PASS |awk -F, {'print $3'} > $DIR/tmp/$GRID-$VO-compute-sites.txt
-n=0
-for i in $(/bin/awk -F: '{print $1}' $DIR/tmp/$GRID-$VO-compute-sites.txt)
-do
-  globusrun -a -r $i/jobmanager-fork 1>/dev/null && echo $i >>  $DIR/tmp/$GRID-$VO-sites-authentication-success-$CDATE.txt &
-  n=`expr $n + 1`
-done
-n=`expr $n / 10`
-n=`expr $n + 10`
-sleep $n
-m=0
-if [ -f  $DIR/tmp/$GRID-$VO-sites-authentication-success-$CDATE.txt ]; then
- for SITE in $(cat $DIR/tmp/$GRID-$VO-sites-authentication-success-$CDATE.txt)
- do
-  /bin/grep $SITE $DIR/bin/.osg-sites.cache >> $DIR/tmp/$GRID-$VO-avail-sites-$CDATE.txt &&  m=`expr $m + 1`
- done
-  echo "Now it's `date +%D-%R`.Altogether,there are $m successful available grid sites."
-  echo "The available sites file for the application deployment is: $DIR/tmp/$GRID-$VO-avail-sites-$CDATE.txt"
-fi
-#generate the swift-sites.xml
-cp $DIR/bin/.swift-sites.xml $DIR/swift-execution-example/swift-sites.xml
-sed -i "s,\$VO/\$USER,$VO/$USER,g" $DIR/swift-execution-example/swift-sites.xml
-echo "The general sites file for swift execution is: $DIR/swift-execution-example/swift-sites.xml"
-#invoke the sites cache and .swift-sites.xml update process
-#$DIR/bin/auto-update-sites $GRID $VO $DIR/tmp/$GRID-$VO-sites-authentication-success-$CDATE.txt &
