[Swift-commit] r2282 - log-processing/libexec
Mon Oct 6 20:42:23 CDT 2008
Author: benc
Date: 2008-10-06 20:42:22 -0500 (Mon, 06 Oct 2008)
New Revision: 2282
Modified:
   log-processing/libexec/everylog-vs-versions
Log:
fix a hardcoded path that should be taken from command line
Modified: log-processing/libexec/everylog-vs-versions
--- log-processing/libexec/everylog-vs-versions	2008-10-06 16:44:34 UTC (rev 2281)
+++ log-processing/libexec/everylog-vs-versions	2008-10-07 01:42:22 UTC (rev 2282)
@@ -14,6 +14,6 @@
 find $1 -name \*.log -and -not -name cluster-\*  -exec basename {} \; | sed 's/^\(.*\)-........-....-........\.log$/\1/' | sort | uniq -c | sort -nr > everylog-basenames-scores.txt
-./everylog-durations-of-workflows ~/work/everylog/ | sort -k 2 > tmp-evl-duration
+./everylog-durations-of-workflows $1 | sort -k 2 > tmp-evl-duration
 ./sum-tt1.pl < tmp-evl-duration  | sort -r -n -k 2 > everylog-cumulative-durations-per-basename.txt
