[Swift-commit] r2349 - trunk/src/org/griphyn/vdl/karajan/lib
Thu Nov 27 16:52:03 CST 2008
Author: benc
Date: 2008-11-27 16:52:02 -0600 (Thu, 27 Nov 2008)
New Revision: 2349
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
Log:
remove dead code from filename and tighten up some method signatures on helper methods
Modified: trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2008-11-27 21:44:04 UTC (rev 2348)
+++ trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2008-11-27 22:52:02 UTC (rev 2349)
@@ -173,40 +173,16 @@
 	public static final String[] EMPTY_STRING_ARRAY = new String[0];
-	 * Given a field (or Collection of fields) on the stack, returns the
-	 * filename(s) that are mapped that field(s).
 	public String[] filename(VariableStack stack) throws ExecutionException {
-		Object ovar = PA_VAR.getValue(stack);
-		if (ovar instanceof DSHandle) {
-			try {
-				return filename((DSHandle) ovar);
-			catch (HandleOpenException e) {
-				throw new FutureNotYetAvailable(addFutureListener(stack, e.getSource()));
+		DSHandle ovar = (DSHandle)PA_VAR.getValue(stack);
+		try {
+			return filename(ovar);
-		else if (ovar instanceof Collection) {
-			return filename((Collection) ovar);
+		catch (HandleOpenException e) {
+			throw new FutureNotYetAvailable(addFutureListener(stack, e.getSource()));
-		else {
-			return new String[0];
-	public String[] filename(Collection vars) throws ExecutionException {
-		// assume here that the Collection is all DSHandles
-		Iterator iterator = vars.iterator();
-		ArrayList out = new ArrayList();
-		while (iterator.hasNext()) {
-			DSHandle h = (DSHandle) iterator.next();
-			String filename = leafFileName(h);
-			out.add(filename);
-		return (String[]) out.toArray(EMPTY_STRING_ARRAY);
 	public String[] filename(DSHandle var) throws ExecutionException, HandleOpenException {
 		try {
 			if (var.getType().isArray()) {
@@ -221,7 +197,7 @@
-	public String[] leavesFileNames(DSHandle var) throws ExecutionException, HandleOpenException {
+	private String[] leavesFileNames(DSHandle var) throws ExecutionException, HandleOpenException {
 		List l = new ArrayList();
 		Iterator i;
 		try {
@@ -292,7 +268,7 @@
-	public String leafFileName(DSHandle var) throws ExecutionException {
+	private String leafFileName(DSHandle var) throws ExecutionException {
 		if (Types.STRING.equals(var.getType())) {
 			return relativize(String.valueOf(var.getValue()));
@@ -394,17 +370,6 @@
-	protected String getFileName(VariableStack stack) throws ExecutionException {
-		DSHandle var = (DSHandle) PA_VAR.getValue(stack);
-		try {
-			Path path = parsePath(PA_PATH.getValue(stack), stack);
-			return leafFileName(var.getField(path));
-		catch (InvalidPathException e) {
-			throw new ExecutionException(e);
 	protected boolean compatible(Type expectedType, Type actualType) {
 		if (expectedType.equals(Types.FLOAT)) {
 			if (actualType.equals(Types.FLOAT) || actualType.equals(Types.INT)) {
