[Swift-commit] r2325 - trunk/tests/language-behaviour
Wed Nov 5 12:43:54 CST 2008
Author: benc
Date: 2008-11-05 12:43:53 -0600 (Wed, 05 Nov 2008)
New Revision: 2325
Modified:
   trunk/tests/language-behaviour/run
Log:
output name of failed test
Modified: trunk/tests/language-behaviour/run
--- trunk/tests/language-behaviour/run	2008-11-05 08:04:04 UTC (rev 2324)
+++ trunk/tests/language-behaviour/run	2008-11-05 18:43:53 UTC (rev 2325)
@@ -42,7 +42,7 @@
   else
 	echo Running test $t
 	swift ${SWIFT_TEST_PARAMS} ${t}.swift
-	if [ "$?" -ne "0" ]; then echo "SWIFT RETURN CODE NON-ZERO"; exit 1; fi
+	if [ "$?" -ne "0" ]; then echo "SWIFT RETURN CODE NON-ZERO - test $testfn"; exit 1; fi
 	echo expecting $EXPECTEDS
   fi
@@ -64,7 +64,7 @@
       			exit $?
       		fi
       	else
-	      	echo "OUTPUT DIFFERS"
+	      	echo "OUTPUT DIFFERS - test $testfn"
 	      	exit 1
 	    fi
       fi
