[Swift-commit] r2076 - trunk/docs
Tue Jun 17 06:55:24 CDT 2008
Author: benc
Date: 2008-06-17 06:55:23 -0500 (Tue, 17 Jun 2008)
New Revision: 2076
Modified:
   trunk/docs/userguide.xml
Log:
doc for condor_requirements profile
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml	2008-06-16 14:35:08 UTC (rev 2075)
+++ trunk/docs/userguide.xml	2008-06-17 11:55:23 UTC (rev 2076)
@@ -2279,6 +2279,9 @@
 The valid values are site-specific. This profile entry is used by the
 GRAM2 and GRAM4 providers.
 			</para>
+			<para id="profile.globus.condor_requirements"><property>condor_requirements</property> allows a requirements string to be specified
+when Condor is used as an LRM behind GRAM2. Example: <profile namespace="globus" key="condor_requirements">Arch == "X86_64" || Arch="INTEL"</profile>
+			</para>
 		</section>
 		<section id="profile.env"><title>env namespace</title>
 			<para>
