[Swift-commit] r2070 - trunk/src/org/griphyn/vdl/engine
Sun Jun 15 16:10:27 CDT 2008
Author: benc
Date: 2008-06-15 16:10:26 -0500 (Sun, 15 Jun 2008)
New Revision: 2070
Modified:
   trunk/src/org/griphyn/vdl/engine/Karajan.java
   trunk/src/org/griphyn/vdl/engine/VariableScope.java
Log:
remove old constructor that has been superceded
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2008-06-15 21:03:09 UTC (rev 2069)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2008-06-15 21:10:26 UTC (rev 2070)
@@ -183,7 +183,7 @@
 	public void procedure(Procedure proc, VariableScope containingScope) throws CompilationException {
 		VariableScope outerScope = new VariableScope(this, null);
-		VariableScope innerScope = new VariableScope(this, outerScope, false);
+		VariableScope innerScope = new VariableScope(this, outerScope, VariableScope.ENCLOSURE_NONE);
 		StringTemplate procST = template("procedure");
 		containingScope.bodyTemplate.setAttribute("procedures", procST);
 		procST.setAttribute("name", proc.getName());
Modified: trunk/src/org/griphyn/vdl/engine/VariableScope.java
--- trunk/src/org/griphyn/vdl/engine/VariableScope.java	2008-06-15 21:03:09 UTC (rev 2069)
+++ trunk/src/org/griphyn/vdl/engine/VariableScope.java	2008-06-15 21:10:26 UTC (rev 2070)
@@ -42,39 +42,13 @@
 	public StringTemplate bodyTemplate;
 	public VariableScope(Karajan c, VariableScope parent) {
-		this(c,parent,true);
+		this(c,parent,ENCLOSURE_ALL);
 	/** Creates a new variable scope.
 		@param c the compiler scope in which this variable lives
 		@param parent the enclosing scope, or null if this is a
 			top level scope
-		@param a if true, assignments made in this scope
-			to variables in an enclosing scope will be permitted. if false,
-			this will be prohibited, which is desirable in loops to prohibit
-			multiple assignment
-		@deprecated use explicit upwards parameter rather than boolean
-	public VariableScope(Karajan c, VariableScope parent, boolean a) {
-		if(parentScope!=null) {
-			logger.info("New scope "+hashCode()+" with parent scope "+parentScope.hashCode());
-		} else {
-			logger.info("New scope "+hashCode()+" with no parent.");
-		compiler = c;
-		parentScope = parent;
-		if(a) {
-			enclosureType = ENCLOSURE_ALL;
-		} else {
-			enclosureType = ENCLOSURE_NONE;
-	/** Creates a new variable scope.
-		@param c the compiler scope in which this variable lives
-		@param parent the enclosing scope, or null if this is a
-			top level scope
 		@param a specifies how assignments to variables made in enclosing
 			scopes will be handled.
