[Swift-commit] r2068 - trunk/tests/misc
Sun Jun 15 15:35:54 CDT 2008
Author: benc
Date: 2008-06-15 15:35:53 -0500 (Sun, 15 Jun 2008)
New Revision: 2068
Added:
   trunk/tests/misc/restart-iterate.sh
Modified:
   trunk/tests/misc/run
Log:
test of iterate with restarts
Added: trunk/tests/misc/restart-iterate.sh
--- trunk/tests/misc/restart-iterate.sh	                        (rev 0)
+++ trunk/tests/misc/restart-iterate.sh	2008-06-15 20:35:53 UTC (rev 2068)
@@ -0,0 +1,95 @@
+#!/bin/bash
+export CF=swift.properties.restart-iterate
+cat $(dirname $(which swift))/../etc/swift.properties | grep --invert-match -E '^lazy.errors=' > $CF
+echo lazy.errors=true >> $CF
+rm -f *.rlog restart-*.out restart-iterate.kml restart-iterate.xml restart-iterate.*.out restart-iterate.*.out.single-run
+rm -rf _concurrent
+echo "localhost	helperA	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" > tmp.restartOK.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartOK.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartOK.tc.data
+swift -config $CF -tc.file tmp.restartOK.tc.data restart-iterate.swift
+PRECHECKEXIT=$?
+if [ "$PRECHECKEXIT" != 0 ]; then
+  echo Failed - attempt to run workflow without restart configuration failed
+  exit 1
+fi
+for fn in restart-iterate.*.out; do
+mv $fn ${fn}.single-run
+done
+rm -rf _concurrent
+echo "localhost	helperA	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" > tmp.restartA.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-fail	INSTALLED	INTEL32::LINUX	null" >> tmp.restartA.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartA.tc.data
+swift -config $CF -tc.file tmp.restartA.tc.data restart-iterate.swift
+FIRSTEXIT=$?
+# this invocation should fail, with restart-1.out in existence but
+# not the others
+if [ "$FIRSTEXIT" == 0 ]; then
+  echo Failed - workflow was indicated as successfully completed the first time round.
+  exit 2
+fi
+for i in 0 1 2 3 4 ; do
+  if [ ! -f restart-iterate.000$i.out ] ; then
+    echo Some first-time output files were missing
+    exit 4
+  fi
+done
+for i in 05 06 07 08 09 10 ; do
+  if [ -f restart-iterate.00$i.out ] ; then
+    echo Second-time output file appeared in first-time run
+    exit 5
+  fi
+done
+# now make A fail - we should have run it already, and so we want to make
+# sure it does not run again; and make B succeed this time round.
+echo "localhost	helperA	$(pwd)/restart5-helper-fail	INSTALLED	INTEL32::LINUX	null" > tmp.restartB.tc.data
+echo "localhost	helperB	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartB.tc.data
+echo "localhost	helperC	$(pwd)/restart5-helper-success	INSTALLED	INTEL32::LINUX	null" >> tmp.restartB.tc.data
+# there should be only a single rlog here, because we deleted them all
+# at the start of this script.
+swift -config $CF -resume *.rlog -tc.file tmp.restartB.tc.data restart-iterate.swift
+SECONDEXIT=$?
+if [ "$SECONDEXIT" != "0" ]; then
+  echo Failed - second round failed
+  exit 3
+fi
+if [ ! -f restart-iterate.0002.out ] ; then
+  echo Second-time output file missing
+  exit 5
+fi
+for i in 1 2 3; do
+   diff -q restart-iterate.000$i.out restart-iterate.000$i.out.single-run
+   if [ "$?" -ne "0" ]; then
+     echo restart-based output file $i differs from non-restarted output file
+     exit 6
+   fi
+done
+echo restart-iterate success
+exit 0
Property changes on: trunk/tests/misc/restart-iterate.sh
___________________________________________________________________
Modified: trunk/tests/misc/run
--- trunk/tests/misc/run	2008-06-15 19:51:16 UTC (rev 2067)
+++ trunk/tests/misc/run	2008-06-15 20:35:53 UTC (rev 2068)
@@ -1,5 +1,5 @@
 #!/bin/sh
-for a in clusters no-retries dryrun typecheck path-prefix restart restart2 restart3 restart4 restart5 workernode-local; do
+for a in clusters no-retries dryrun typecheck path-prefix restart restart2 restart3 restart4 restart5 restart-iterate workernode-local; do
  ./${a}.sh
  R=$?
  echo test $a ended with return value $R
