[Swift-commit] r2059 - gasateria/bin
Thu Jun 12 15:57:23 CDT 2008
Author: houzx
Date: 2008-06-12 15:57:22 -0500 (Thu, 12 Jun 2008)
New Revision: 2059
Removed:
   gasateria/bin/update-sites-cache-
Log:
Deleting file 'update-sites-cache-'
Deleted: gasateria/bin/update-sites-cache-
--- gasateria/bin/update-sites-cache-	2008-06-11 21:43:56 UTC (rev 2058)
+++ gasateria/bin/update-sites-cache-	2008-06-12 20:57:22 UTC (rev 2059)
@@ -1,59 +0,0 @@
-#/bin/bash
-CDATE=`date +%F-%R`
-DIR=`pwd`
-USER=`whoami`
-# get the grid computing sites
-GRID=$1
-VO=$2
-if [ "$GRID" == "" ]; then
-  echo "Please input the GRID name as the first parameter."
-  echo "The GRID can be:osg osg-itb (teragrid?)"
-  echo "If necessary, please input the virtual organization name as the second parameter.Just use a space to separate the two parameters."
-  echo "For osg, vo can be:CDF CMS CompBioGrid DES DOSAR DZero Engage Fermilab fMRI GADU geant4 GLOW GPN GRASE GridChem GridEx GROW i2u2 iVDGL LIGO mariachi MIS  nanoHUB NWICG  Ops  OSG OSGEDU SDSS STAR USATLAS"
-  exit
-fi
-  if [ "$VO" == "" ]; then
-  /usr/bin/wget -O $DIR/tmp/$VO-vo-sitelist.txt "http://vors.grid.iu.edu/cgi-bin/tindex.cgi?grid=$GRID" 1>/dev/null 2>/dev/null
-  else
-   /usr/bin/wget -O $DIR/tmp/$VO-vo-sitelist.txt "http://vors.grid.iu.edu/cgi-bin/tindex.cgi?grid=$GRID&VO=$VO" 1>/dev/null 2>/dev/null
- fi
-/bin/cat $DIR/tmp/$VO-vo-sitelist.txt |grep compute |grep PASS |awk -F, {'print $3'} > $DIR/tmp/$GRID-$VO-compute-sites.txt
-#touch sites-$CDATE.txt
-#for i in $(cat $DIR/tmp/$GRID-$VO-compute-sites.txt)
-for i in $(/bin/awk -F: '{print $1}' $DIR/tmp/$GRID-$VO-compute-sites.txt)
-do
-  echo $i >>  $DIR/tmp/sites-$CDATE.txt
-  globusrun -a -r $i/jobmanager-fork >>  $DIR/tmp/sites-$CDATE.txt
-done
-if [ -f  $DIR/tmp/sites-$CDATE.txt ]; then
-  m=0
-  for i in $(sed -n '/success/='  $DIR/tmp/sites-$CDATE.txt)
-do
-   #echo $i
-   m=`expr $m + 1`
-   j=`expr $i - 2`
-   S=`sed -n "$j"p  $DIR/tmp/sites-$CDATE.txt`
-   echo $S >>  $DIR/tmp/$GRID-$VO-sites-success-$CDATE.txt
-done
-  echo " Now it's `date +%D-%R`.Altogether, there are $m successful available grid sites."
-fi
-#If there is new sites, update sites cache
-if [ $m > 24 ]; then
- for SITE in $(cat $DIR/tmp/$GRID-$VO-sites-success-$CDATE.txt)
- do
-  /bin/grep $SITE $DIR/.osg-sites.cache >> $DIR/tmp/$GRID-$VO-avail-sites-$CDATE.txt
- done
-fi
-#clean the files
-/bin/rm -rf $DIR/tmp/sites-$CDATE.txt  $DIR/tmp/$GRID-$VO-sites-success-$CDATE.txt
