[Swift-commit] r2379 - provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky
Fri Dec 19 13:48:05 CST 2008
Author: benc
Date: 2008-12-19 13:48:03 -0600 (Fri, 19 Dec 2008)
New Revision: 2379
Modified:
   provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java
Log:
tidy up source a bit
Modified: provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java
--- provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java	2008-12-19 16:33:30 UTC (rev 2378)
+++ provider-wonky/src/org/globus/cog/abstraction/impl/execution/wonky/JobSubmissionTaskHandler.java	2008-12-19 19:48:03 UTC (rev 2379)
@@ -74,7 +74,7 @@
             throw new TaskSubmissionException("Task is not in unsubmitted state");
         else {
-logger.info("Submitting wonky job "+jobNumber);
+            logger.info("Submitting wonky job "+jobNumber);
             this.task = task;
@@ -82,7 +82,7 @@
                 .getServiceContact();
             String server = serviceContact.getContact();
-logger.debug("Contact is: "+server);
+            logger.debug("Contact is: "+server);
             String[] splitServer = server.split("/");
 	    siteName = splitServer[0];
             siteOptions = Arrays.asList(splitServer);
@@ -146,17 +146,17 @@
     public void suspend() throws InvalidSecurityContextException,
             TaskSubmissionException {
-logger.info("Suspend called on wonky job "+jobNumber);
+        logger.info("Suspend called on wonky job "+jobNumber);
     public void resume() throws InvalidSecurityContextException,
-logger.info("Resume called on wonky job "+jobNumber);
+        logger.info("Resume called on wonky job "+jobNumber);
     public void cancel() throws InvalidSecurityContextException,
-logger.info("Cancel called on wonky job "+jobNumber);
+        logger.info("Cancel called on wonky job "+jobNumber);
         synchronized(this) {
             killed = true;
             process.destroy();
@@ -176,41 +176,39 @@
             if (spec.getDirectory() != null) {
                 dir = new File(spec.getDirectory());
-logger.info("Wonky job in queue, job number "+jobNumber);
-String[] cmdarray = buildCmdArray(spec, jobNumber);
-try {
-logger.info("wonky site is "+siteName);
-	if(siteOptions.contains("firstfast") && !firstJobList.contains(siteName)) {
-logger.info("not sleeping - this is the first job on site "+siteName+", "+jobNumber);
-firstJobList.add(siteName);
-} else
-double qmean=0;
-double qstddev=0;
+        logger.info("Wonky job in queue, job number "+jobNumber);
+        String[] cmdarray = buildCmdArray(spec, jobNumber);
+        try {
+            logger.info("wonky site is "+siteName);
+            if(siteOptions.contains("firstfast") && !firstJobList.contains(siteName)) {
+                logger.info("not sleeping - this is the first job on site "+siteName+", "+jobNumber);
+                firstJobList.add(siteName);
+            } else {
+                double qmean=0;
+                double qstddev=0;
-Iterator it = siteOptions.iterator();
-while(it.hasNext()) {
-String op = (String) it.next();
-logger.debug("Checking: "+op);
-if(op.startsWith("qmean=")) {
-qmean = Double.parseDouble(op.substring(6));
-logger.debug("qmean = "+qmean);
-} else if(op.startsWith("qstddev=")) {
-qstddev = Double.parseDouble(op.substring(8));
-logger.debug("qstddev = "+qstddev);
+                Iterator it = siteOptions.iterator();
+                while(it.hasNext()) {
+                    String op = (String) it.next();
+                    logger.debug("Checking: "+op);
+                    if(op.startsWith("qmean=")) {
+                        qmean = Double.parseDouble(op.substring(6));
+                        logger.debug("qmean = "+qmean);
+                    } else if(op.startsWith("qstddev=")) {
+                        qstddev = Double.parseDouble(op.substring(8));
+                        logger.debug("qstddev = "+qstddev);
-double qdelay = qmean + qstddev * r.nextGaussian();
+                double qdelay = qmean + qstddev * r.nextGaussian();
-Thread.sleep((long)(qdelay*1000));
-} catch(InterruptedException ie) {
-System.out.println("fake queue delay interrupted for job "+jobNumber);
-System.out.println("Wonky job running now");
-            process = Runtime.getRuntime().exec(cmdarray,
-                    buildEnvp(spec), dir);
+                Thread.sleep((long)(qdelay*1000));
+            } catch(InterruptedException ie) {
+                logger.warn("fake queue delay interrupted for job "+jobNumber);
+            logger.info("Wonky job running now");
+            process = Runtime.getRuntime().exec(cmdarray, buildEnvp(spec), dir);
             if(!failDelay("active")) {
                 this.task.setStatus(Status.FAILED);
                 return;
@@ -389,7 +387,7 @@
         double failFirstCount = getWonkyParam(name+"failfirstcount");
         if(failFirstCount > 0) {
-            System.out.println("State "+name+" will fail first "+failFirstCount+" times");
+            logger.info("State "+name+" will fail first "+failFirstCount+" times");
             String key = getSiteName() + ":" + name + "failfirstcountsofar";
             Integer iObj = (Integer)siteStates.get(key);
             if(iObj == null) {
@@ -400,19 +398,19 @@
             int i = iObj.intValue();
             i++;
             siteStates.put(key,new Integer(i));
-            System.out.println("new value is "+i);
+            logger.info("new value is "+i);
             if(i<=failFirstCount) {  // not failed enough
-                System.out.println("Failing because early job");
+                logger.info("Failing because early job");
                 return false;
-        System.out.print("State "+name+" with probability of failure "+failRate+": ");
+        logger.info("State "+name+" with probability of failure "+failRate+": ");
         if(Math.random()<failRate) {
-            System.out.println("Fail.");
+            logger.info("Fail.");
             return false;
         } else {
-            System.out.println("Success.");
+            logger.info("Success.");
             try { Thread.sleep((long)(delayTime * 1000)); }
                 logger.warn("Warning: wonky delay was interrupted");
@@ -438,7 +436,7 @@
     String getSiteName() {
         String siteName = (String) siteOptions.get(0);
-        System.out.println("Site name is "+siteName);
+        logger.info("Site name is "+siteName);
         return siteName;
