[Swift-commit] r2374 - in trunk: libexec resources src/org/griphyn/vdl/karajan/lib
Mon Dec 15 17:55:15 CST 2008
Author: benc
Date: 2008-12-15 17:55:12 -0600 (Mon, 15 Dec 2008)
New Revision: 2374
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
Modified:
   trunk/libexec/vdl-lib.xml
   trunk/resources/Karajan.stg
   trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java
Log:
separate out arrayiterator construction from getting a field value
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml	2008-12-14 21:22:30 UTC (rev 2373)
+++ trunk/libexec/vdl-lib.xml	2008-12-15 23:55:12 UTC (rev 2374)
@@ -45,6 +45,7 @@
 	<export name="setFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.SetFieldValue"/></export>
 	<export name="getFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.GetFieldValue"/></export>
 	<export name="waitFieldValue"><elementDef classname="org.griphyn.vdl.karajan.lib.WaitFieldValue"/></export>
+	<export name="getArrayIterator"><elementDef classname="org.griphyn.vdl.karajan.lib.GetArrayIterator"/></export>
 	<export name="isFileBound"><elementDef classname="org.griphyn.vdl.karajan.lib.IsFileBound"/></export>
 	<export name="isRestartable"><elementDef classname="org.griphyn.vdl.karajan.lib.IsRestartable"/></export>
 	<export name="fringePaths"><elementDef classname="org.griphyn.vdl.karajan.lib.FringePaths"/></export>
Modified: trunk/resources/Karajan.stg
--- trunk/resources/Karajan.stg	2008-12-14 21:22:30 UTC (rev 2373)
+++ trunk/resources/Karajan.stg	2008-12-15 23:55:12 UTC (rev 2374)
@@ -201,7 +201,7 @@
 foreach(var,in,indexVar,declarations,statements) ::= <<
 <parallelFor name="\$">
-  <getfieldvalue>$in$</getfieldvalue>
+  <getarrayiterator>$in$</getarrayiterator>
   <set names="\$\$, $var$">
     <each items="{\$}"/>
   </set>
Added: trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java	2008-12-15 23:55:12 UTC (rev 2374)
@@ -0,0 +1,57 @@
+package org.griphyn.vdl.karajan.lib;
+import java.util.Map;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.ExecutionException;
+import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
+import org.griphyn.vdl.karajan.PairIterator;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.mapping.InvalidPathException;
+import org.griphyn.vdl.mapping.Path;
+public class GetArrayIterator extends VDLFunction {
+	public static final Logger logger = Logger.getLogger(GetArrayIterator.class);
+	static {
+		setArguments(GetArrayIterator.class, new Arg[] { PA_VAR, OA_PATH });
+	 * Takes a supplied variable and path, and returns an array iterator.
+	public Object function(VariableStack stack) throws ExecutionException {
+		Object var1 = PA_VAR.getValue(stack);
+		if (!(var1 instanceof DSHandle)) {
+			return var1;
+		DSHandle var = (DSHandle) var1;
+		try {
+			Path path = parsePath(OA_PATH.getValue(stack), stack);
+			if (path.hasWildcards()) {
+				throw new RuntimeException("Wildcards not supported");
+			else {
+				var = var.getField(path);
+				if (var.getType().isArray()) {
+					Map value = var.getArrayValue();
+					if (var.isClosed()) {
+						return new PairIterator(value);
+					else {
+						return addFutureListListener(stack, var, value);
+				} else {
+					throw new RuntimeException("Cannot get array iterator for non-array");
+		catch (InvalidPathException e) {
+			throw new ExecutionException(e);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java	2008-12-14 21:22:30 UTC (rev 2373)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java	2008-12-15 23:55:12 UTC (rev 2374)
@@ -10,7 +10,6 @@
-import org.griphyn.vdl.karajan.PairIterator;
@@ -49,14 +48,7 @@
 			else {
-					// this bit from GetArrayFieldValue
-					Map value = var.getArrayValue();
-					if (var.isClosed()) {
-						return new PairIterator(value);
-					else {
-						return addFutureListListener(stack, var, value);
+					throw new RuntimeException("Getting value for array "+var+" which is not permitted.");
 				synchronized (var) {
 					if (!var.isClosed()) {
