[Swift-commit] r2355 - log-processing/bin
Tue Dec 2 10:21:41 CST 2008
Author: benc
Date: 2008-12-02 10:21:40 -0600 (Tue, 02 Dec 2008)
New Revision: 2355
Added:
   log-processing/bin/swift2cedps
Log:
commandline utility to drive CEDPS format log conversion
Added: log-processing/bin/swift2cedps
--- log-processing/bin/swift2cedps	                        (rev 0)
+++ log-processing/bin/swift2cedps	2008-12-02 16:21:40 UTC (rev 2355)
@@ -0,0 +1,52 @@
+#!/bin/bash
+ORIGDIR=$(pwd)
+WORKINGDIR=$(mktemp -d /tmp/swift-plot-log-XXXXXXXXXXXXXXXX)
+# $1 should be the pathname of the log file to plot
+LOG_CODE_HOME="`dirname $0`/../libexec/"
+export SWIFT_PLOT_HOME=$LOG_CODE_HOME
+export PATH=${LOG_CODE_HOME}:${PATH}
+FC="${1:0:1}"
+if [ "$FC" = "/" ]; then # absolute path
+  LOG_FILE_PATH=$1
+else
+  LOG_FILE_PATH="`pwd`/$1"
+fi
+LOG_DIRECTORY=`dirname $LOG_FILE_PATH`
+LOG_FILE_BASE=`basename $LOG_FILE_PATH .log`
+echo Log file path is $LOG_FILE_PATH
+echo Log is in directory $LOG_DIRECTORY
+echo Log basename is $LOG_FILE_BASE
+cd $WORKINGDIR
+echo Now in directory $(pwd)
+MAKEENV="-f ${LOG_CODE_HOME}/makefile -I ${LOG_CODE_HOME}"
+MAKETARGETS=""
+INFODIR=${LOG_DIRECTORY}/${LOG_FILE_BASE}.d
+if [ -d $INFODIR ]; then
+ MAKEENV="$MAKEENV IDIR=${LOG_DIRECTORY}/${LOG_FILE_BASE}.d/"
+ MAKETARGETS="webpage.info"
+fi
+make $MAKEENV SDL=${ORIGDIR}/report-${LOG_FILE_BASE} LOG=$LOG_FILE_PATH clean execute.cedps execute2.cedps karatasks.cedps
+cp -v *.cedps $ORIGDIR
+# webpage.kara webpage.weights karatasks.JOB_SUBMISSION.Queue.transitions karatasks.JOB_SUBMISSION.Queue.event karatasks.JOB_SUBMISSION.eip  $MAKETARGETS webpage distribute
+# mv report-$LOG_FILE_BASE $LOG_DIRECTORY/
+# rm -r $WORKINGDIR
+echo not removing $WORKINGDIR
Property changes on: log-processing/bin/swift2cedps
___________________________________________________________________
