[Swift-commit] r2207 - trunk
Wed Aug 27 06:24:28 CDT 2008
Author: benc
Date: 2008-08-27 06:24:27 -0500 (Wed, 27 Aug 2008)
New Revision: 2207
Modified:
   trunk/build.xml
Log:
option to make distribution without command grid commands such as grid-proxy-init, to facilitate installation inside a VDT install
Modified: trunk/build.xml
--- trunk/build.xml	2008-08-27 10:04:21 UTC (rev 2206)
+++ trunk/build.xml	2008-08-27 11:24:27 UTC (rev 2207)
@@ -92,6 +92,7 @@
 			<fileset dir="${dist.dir}/bin"
 				includes="globus2jks*, grid-info-search*, cogrun*, globus-gass-server-shutdown*"/>
 		</delete>
+		<antcall target="remove-supporting" />
 		<copy todir="${dist.dir}/etc"
 			file="${cog.dir}/modules/${module.name}/etc/karajan.properties"
 			overwrite="true"/>
@@ -276,6 +277,13 @@
 	<target name="redist" depends="distclean, dist">
 	</target>
+       <target name="remove-supporting" if="no-supporting">
+ 		<delete>
+			<fileset dir="${dist.dir}/bin"
+				includes="cog*, globus*, grid*"/>
+		</delete>
+        </target>
 </project>
