[Swift-commit] r2177 - trunk/src/org/griphyn/vdl/karajan
Wed Aug 6 03:57:32 CDT 2008
Author: benc
Date: 2008-08-06 03:57:27 -0500 (Wed, 06 Aug 2008)
New Revision: 2177
Removed:
   trunk/src/org/griphyn/vdl/karajan/VDSScheduler.java
Log:
remove unused old scheduler - this has dependencies on VDS precompiled java classes that I am trying to eliminate.
Deleted: trunk/src/org/griphyn/vdl/karajan/VDSScheduler.java
--- trunk/src/org/griphyn/vdl/karajan/VDSScheduler.java	2008-08-05 14:14:06 UTC (rev 2176)
+++ trunk/src/org/griphyn/vdl/karajan/VDSScheduler.java	2008-08-06 08:57:27 UTC (rev 2177)
@@ -1,83 +0,0 @@
- * Created on Jun 12, 2006
-package org.griphyn.vdl.karajan;
-import java.util.ArrayList;
-import java.util.List;
-import org.globus.cog.karajan.scheduler.LateBindingScheduler;
-import org.globus.cog.karajan.scheduler.NoFreeResourceException;
-import org.globus.cog.karajan.scheduler.TaskConstraints;
-import org.globus.cog.karajan.util.BoundContact;
-import org.globus.cog.karajan.util.ContactSet;
-import org.griphyn.cPlanner.classes.SubInfo;
-import org.griphyn.cPlanner.selector.SiteSelector;
-import org.griphyn.cPlanner.selector.site.RoundRobin;
-import org.griphyn.common.catalog.transformation.Mapper;
-import org.griphyn.common.catalog.transformation.mapper.Installed;
-public class VDSScheduler extends LateBindingScheduler {
-	private SiteSelector siteSelector;
-	private List pools;
-	private Mapper tcmapper;
-	public VDSScheduler() {
-		this.siteSelector = new RoundRobin();
-		this.siteSelector.setTCMapper(tcmapper = new Installed());
-		this.addTaskTransformer(new VDSTaskTransformer(tcmapper));
-	public void setResources(ContactSet grid) {
-		super.setResources(grid);
-		pools = new ArrayList();
-		for (int i = 0; i < grid.size(); i++) {
-			pools.add(grid.get(i).getHost());
-	protected BoundContact getNextContact(TaskConstraints t) throws NoFreeResourceException {
-		String host = siteSelector.mapJob2ExecPool(toSubInfo(t), pools);
-		if (host.endsWith(":null")) {
-			host = host.substring(0, host.length() - 5);
-		BoundContact bc = getResources().getContact(host);
-		if (bc == null) {
-			throw new RuntimeException("Could not find a valid site for transformation '"
-					+ t.getConstraint("tr") + "'");
-		else {
-			return bc;
-	private SubInfo toSubInfo(TaskConstraints t) {
-		SubInfo si = new SubInfo();
-		if (isPresent("tr", t)) {
-			String tr = (String) t.getConstraint("tr");
-			si.setTransformation(null, tr, null);
-			si.setJobClass(SubInfo.STAGED_COMPUTE_JOB);
-		return si;
-	private boolean isPresent(String constraint, TaskConstraints t) {
-		if (t == null) {
-			return false;
-		if (t.getConstraint(constraint) == null) {
-			return false;
-		return true;
-	public void setProperty(String name, Object value) {
-		if ("siteSelectorClassName".equals(name)) {
-			this.siteSelector = SiteSelector.loadSiteSelector((String) value, null);
-			this.siteSelector.setTCMapper(new Installed());
-		else {
-			super.setProperty(name, value);
