sieve-dev mesh loading and distribution
Shi Jin jinzishuai at gmail.com
Thu Oct 30 10:39:28 CDT 2008
Hi there,
I have been thinking about issue of large memory cost and slow process
of loading and distributing mesh. I have three points and would
appreciate your comment.
1. I realized that a major difficulty lies in the treatment of edge
and faces, ie, the interpolation of the mesh. In fact, it is fairly
straightforward to have an efficient code that only deals with first
order elements, ie, in the sieve structure, there are only two layers,
cells and vertexes. Our input files are  actually for a linear element
mesh. The master process loads it in and spends a lot of time and
memory doing the interpolation. This part is not parallelized. I am
wondering if it is possible to make the interpolation run in parallel
too. We can first distribute the uninterpolated mesh across processes,
which can be done much more efficiently with much less resources.
After the distribution, we do a interpolation locally on each process.
Surely we have an issue of overlaps and renumbering for the newly
introduced points. So this is definitely a very non-trivial task. But
once it is implemented, we are able to run much larger meshes since
the cost is shared by lots of processes.
2. Since linear elements are fairly easy to do, I wrote my own code to
load in the same input files (.nodes and .lcon files). From that, I
can construct the inverse connectivity table and then produce the same
sieve data structure. This code is able to produce the same first
order grid as using the loadMesh() directly for linear elements.
However, I only use about 1/3 of the memory and spent 25% less time in
doing this. Are you interested in my implementation? My inverse
connectivity table in allocated as a single continuous 1-D array, with
length=NumberofVertex*MaxSupportSize, where the MaxSupportSize is a
number I can control by command line options. For the mesh I am using,
MaxSupportSize=24. So my code is not as general as yours in this
sense. My cone and coneOrientation data are identical to the one
obtained in your code (the coneOrientation are all 0s for a serial
code, right?), which is just the connectivity table in the input .lcon
file. My support data are the same but not ordered as yours, since I
did not use the STL list data structure. If I am to sort it, it is
definitely going to be more expensive. Is the order of support points
important? I am very happy to share the code.
Unfortunately my code has to use second order elements so I cannot
fully test this.  The importance of this part will only be critical
after the first issue of parallel interpolation is solved.
3. I also realized that the support data are very expensive to obtain.
Basically from my experience in the linear element case in point 2, I
found the inverse connectivity table taking a lot of memory and time.
However, the inverse connectivity table is not also used. In some
applications, it is not necessary to have the inverse connectivity
table (thus the support of a point) information. For those cases, is
it possible not to set the support information? If that is true, we
can save the a very large portion of the computational resources.
Thank you very much.
Sincerely,
Shi Jin, Ph.D.
http://www.ualberta.ca/~sjin1/
More information about the sieve-dev mailing list
