[petsc-users] Install PETSc with option `--with-shared-libraries=1` failed on MacOS
Barry Smith bsmith at petsc.dev
Sun Mar 17 09:04:16 CDT 2024
  I would just avoid the --download-openblas  option. The BLAS/LAPACK provided by Apple should perform fine, perhaps even better than OpenBLAS on your system.
> On Mar 17, 2024, at 9:58 AM, Zongze Yang <yangzongze at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Adding the flag `--download-openblas-make-options=TARGET=GENERIC` did not resolve the issue. The same error persisted.
> Best wishes,
> Zongze
>> On 17 Mar 2024, at 20:58, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>> On 17 Mar 2024, at 1:04 PM, Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>>> Thank you for providing the instructions. I try the first option.
>>> Now, the error of the configuration is related to OpenBLAS.
>>> Add `--CFLAGS=-Wno-int-conversion` to configure command resolve this. Should this be reported to OpenBLAS? Or need to fix the configure in petsc?
>> I see our linux-opt-arm runner is using the additional flag '--download-openblas-make-options=TARGET=GENERIC', could you maybe try to add that as well?
>> I don’t think there is much to fix on our end, OpenBLAS has been very broken lately on arm (current version is 0.3.26 but we can’t update because there is a huge performance regression which makes the pipeline timeout).
>> Thanks,
>> Pierre
>>> The configure.log is attached. The errors are show below:
>>>     src/lapack_wrappers.c:570:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>>         RELAPACK_sgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>>     src/../inc/relapack.h:74:216: note: passing argument to parameter here
>>>     void RELAPACK_sgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
>>>     src/lapack_wrappers.c:583:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>>         RELAPACK_dgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>>     src/../inc/relapack.h:75:221: note: passing argument to parameter here
>>>     void RELAPACK_dgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
>>>     src/lapack_wrappers.c:596:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>>         RELAPACK_cgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>>     src/../inc/relapack.h:76:216: note: passing argument to parameter here
>>>     void RELAPACK_cgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
>>>     src/lapack_wrappers.c:609:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>>         RELAPACK_zgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>>     src/../inc/relapack.h:77:221: note: passing argument to parameter here
>>>     void RELAPACK_zgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
>>>     4 errors generated.
>>> Best wishes,
>>> Zongze
>>> <configure.log.tar.gz>
>>>> On 17 Mar 2024, at 18:48, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>> You need this MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7365__;!!G_uCfscf7eWS!eOGIcMBe3EV8va7MfOwaPaSEEZWB0R4RNvzMgW8PRyySg08UkUdgsHoooFig3Oai-akPT9jYBu9bh5e2Mgqi_ao$  <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7365__;!!G_uCfscf7eWS!eCQRfbol7FDQiO0o78iDit2saij_ydIUtCfRQnsQAt-h_YcXr2Yi2BFnFnqHZp0FO3Lhpyr2RKdHZ-T-OF94HpwQ$>
>>>> main has been broken for macOS since https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7341__;!!G_uCfscf7eWS!eOGIcMBe3EV8va7MfOwaPaSEEZWB0R4RNvzMgW8PRyySg08UkUdgsHoooFig3Oai-akPT9jYBu9bh5e2sXmUpjA$  <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7341__;!!G_uCfscf7eWS!eCQRfbol7FDQiO0o78iDit2saij_ydIUtCfRQnsQAt-h_YcXr2Yi2BFnFnqHZp0FO3Lhpyr2RKdHZ-T-OIhlJwLx$>, so the alternative is to revert to the commit prior.
>>>> It should work either way.
>>>> Thanks,
>>>> Pierre
>>>>> On 17 Mar 2024, at 11:31 AM, Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>>>>> Hi, PETSc Team,
>>>>> I am trying to install petsc with the following configuration
>>>>> ./configure \
>>>>>     --download-bison \
>>>>>     --download-mpich \
>>>>>     --download-mpich-configure-arguments=--disable-opencl \
>>>>>     --download-hwloc \
>>>>>     --download-hwloc-configure-arguments=--disable-opencl \
>>>>>     --download-openblas \
>>>>>     --download-openblas-make-options="'USE_THREAD=0 USE_LOCKING=1 USE_OPENMP=0'" \
>>>>>     --with-shared-libraries=1 \
>>>>>     --with-fortran-bindings=0 \
>>>>>     --with-zlib \
>>>>>     LDFLAGS=-Wl,-ld_classic
>>>>> The log shows that
>>>>>    Exhausted all shared linker guesses. Could not determine how to create a shared library!
>>>>> I recently updated the system and Xcode, as well as homebrew.
>>>>> Thanks for your attention to this matter.
>>>>> Best wishes,
>>>>> Zongze
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240317/bd5c76eb/attachment-0001.html>
