[petsc-users] snes matrix-free jacobian fails with preconditioner shape mismatch
Mark Adams mfadams at lbl.gov
Mon Mar 11 07:10:57 CDT 2024
I think you misunderstand "global" vector. The global solution is never on
one processor. A global vector in this case seems to have 81 global values
and 27 local values.
It looks like you create a "global" vector that has 81 local values that
should never be created other than for debigging.
GlobalToLocal refers to a "local" vector with ghost cells, so it would have
> 27 values in this case and you use it for local operations only (its
communicator is PETSC_COMM_SELF).
Hope this helps,
On Mon, Mar 11, 2024 at 4:48 AM Yi Hu <y.hu at mpie.de> wrote:
> Dear Barry,
> Thanks for your response. Now I am doing simple debugging for my
> customized mat_mult_op of my shell jacobian matrix. As far as I understand,
> because the input and output of shell jacobian are all global vectors, I
> need to do the global to local mapping of my input vector (dF) by myself.
> Before starting debugging the mapping, I first try to verify the size match
> of input and output.
> Because the input and output of a mat_mult_op of my shell matrix should
> have the same size. So I tried just equating them in my customized
> mat_mult_op. Basically like this
> subroutine GK_op(Jac,dF_global,output_global,err_PETSc)
>   DM                                   :: dm_local ! Yi: later for is,ie
>   Vec                                  :: dF_global
>   Vec                                  :: output_global
>   PetscErrorCode                       :: err_PETSc
>   real(pREAL), pointer,dimension(:,:,:,:) :: dF_scal, output_scal
>   call SNESGetDM(SNES_mech,dm_local,err_PETSc)
>   CHKERRQ(err_PETSc)
>   output_global = dF_global
> end subroutine GK_op
> When I run with mpirun -np 3, it gives me similar error like previous,
> “Preconditioner number of local rows 27 does not equal input vector size
> 81”, (I changed my problem size so the numbers are different).
> Maybe simple equating input and output is not valid (due to ownership of
> different portion of a global vector). Then it may give me different error
> message. In fact my global dF has size 9*3*3*3, when running on 3
> processors, the local dF has size 9*3*3*1 (I split my domain in z
> direction). The error message seems to suggest I am using a local dF rather
> than a global dF. And the output and input vector sizes seems to be
> different. Do I miss something here?
> Best regards,
> Yi
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Sunday, March 10, 2024 6:45 PM
> *To:* Yi Hu <y.hu at mpie.de>
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] snes matrix-free jacobian fails with
> On Mar 10, 2024, at 10:16 AM, Yi Hu <y.hu at mpie.de> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear Mark,
> Thanks for your reply. I see this mismatch. In fact my global DoF is 324.
> It seems like I always get the local size = global Dof / np^2, np is my
> processor number. By the way, I used DMDASNESsetFunctionLocal() to set my
> form function. Is it eligible to mix DMDASNESsetFunctionLocal() and a
> native SNESSetJacobian()?
> Yes
> Best,
> Yi
> On 3/10/24 13:55, Mark Adams wrote:
> It looks like your input vector is the global vector, size 162, and the local matrix size is 81.
> Mark
> [1]PETSC ERROR: Preconditioner number of local rows 81 does not equal
> input vector size 162
> On Sun, Mar 10, 2024 at 7:21 AM Yi Hu <y.hu at mpie.de> wrote:
> *This Message Is From an External Sender *
> Dear petsc team,
> I implemented a matrix-free jacobian, and it can run sequentially. But
> running parallel I got the pc error like this (running with mpirun -np
> 2, only error from rank1 is presented here)
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Nonconforming object sizes
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0PlyUrtdfCA$ <https://urldefense.us/v3/__https:/petsc.org/release/faq/__;!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0PlyUrtdfCA$> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.17.3, Jun 29, 2022
> [1]PETSC ERROR: /home/yi/workspace/DAMASK_yi/bin/DAMASK_grid on a
> arch-linux-c-opt named carbon-x1 by yi Sun Mar 10 12:01:46 2024
> [1]PETSC ERROR: Configure options --download-fftw --download-hdf5
> --with-hdf5-fortran-bindings --download-fblaslapack --download-chaco
> --download-hypre --download-metis --download-mumps --download-parmetis
> --download-scalapack --download-suitesparse --download-superlu
> --download-superlu_dist --download-triangle --download-zlib
> --download-cmake --with-cxx-dialect=C++11 --with-c2html=0
> --with-debugging=0 --with-ssl=0 --with-x=0 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
> FOPTFLAGS=-O3
> [1]PETSC ERROR: #1 PCApply() at
> /home/yi/App/petsc-3.17.3/src/ksp/pc/interface/precon.c:424
> [1]PETSC ERROR: #2 KSP_PCApply() at
> /home/yi/App/petsc-3.17.3/include/petsc/private/kspimpl.h:376
> [1]PETSC ERROR: #3 KSPInitialResidual() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itres.c:64
> [1]PETSC ERROR: #4 KSPSolve_GMRES() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/impls/gmres/gmres.c:242
> [1]PETSC ERROR: #5 KSPSolve_Private() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itfunc.c:902
> [1]PETSC ERROR: #6 KSPSolve() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itfunc.c:1078
> [1]PETSC ERROR: #7 SNESSolve_NEWTONLS() at
> /home/yi/App/petsc-3.17.3/src/snes/impls/ls/ls.c:222
> [1]PETSC ERROR: #8 SNESSolve() at
> /home/yi/App/petsc-3.17.3/src/snes/interface/snes.c:4756
> [1]PETSC ERROR: #9 User provided function() at User file:0
> However, from snes matrix-free documentation
> (https://urldefense.us/v3/__https://petsc.org/release/manual/snes/*matrix-free-methods__;Iw!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0Ply6ZbywOw$ <https://urldefense.us/v3/__https:/petsc.org/release/manual/snes/*matrix-free-methods__;Iw!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0Ply6ZbywOw$>), it is said
> matrix-free is used with pcnone. So I assume it would not apply
> preconditioner, but it did use preconditioning probably the same as my
> matrix-free shell matrix. Here is how i initialize my shell matrix and
> the corresponding customized multiplication.
>    call MatCreateShell(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,&
> int(9*product(cells(1:2))*cells3,pPETSCINT),&
>                        F_PETSc,Jac_PETSc,err_PETSc)
>    call MatShellSetOperation(Jac_PETSc,MATOP_MULT,GK_op,err_PETSc)
>    call SNESSetDM(SNES_mech,DM_mech,err_PETSc)
>    call
> SNESSetJacobian(SNES_mech,Jac_PETSc,Jac_PETSc,PETSC_NULL_FUNCTION,0,err_PETSc)
>    call SNESGetKSP(SNES_mech,ksp,err_PETSc)
>    call PCSetType(pc,PCNONE,err_PETSc)
> And my GK_op is like
> subroutine GK_op(Jac,dF_global,output_local,err_PETSc)
>    DM                                   :: dm_local
>    Vec                                  :: dF_global, dF_local, output_local
>    Mat                                  :: Jac
>    real(pREAL), dimension(3,3,cells(1),cells(2),cells3) :: &
>      dF
>      output
>    call DMGetLocalVector(dm_local,dF_local,err_PETSc)
>    call
> DMGlobalToLocalBegin(dm_local,dF_global,INSERT_VALUES,dF_local,err_PETSc)
>    call
> DMGlobalToLocalEnd(dm_local,dF_global,INSERT_VALUES,dF_local,err_PETSc)
>    call DMDAVecGetArrayReadF90(dm_local,dF_local,dF_scal,err_PETSc)
>    dF = reshape(dF_scal, [3,3,cells(1),cells(2),cells3])
>    call DMDAVecRestoreArrayF90(dm_local,output_local,output_scal,err_PETSc)
>    CHKERRQ(err_PETSc)
>    call DMDAVecRestoreArrayF90(dm_local,dF_local,dF_scal,err_PETSc)
>    CHKERRQ(err_PETSc)
> I checked my cells3, it corresponds to my local size, and it seems the
> local size of dF_local is ok.
> I am a bit lost here to find the reason for the preconditioner bug.
> Could you help me on this? Thanks.
> Best regards,
> Yi
> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
> Max-Planck-Institut für Eisenforschung GmbH
> Max-Planck-Straße 1
> D-40237 Düsseldorf
>  Handelsregister B 2533
> Amtsgericht Düsseldorf
>  Geschäftsführung
> Prof. Dr. Gerhard Dehm
> Prof. Dr. Jörg Neugebauer
> Prof. Dr. Dierk Raabe
> Dr. Kai de Weldige
>  Ust.-Id.-Nr.: DE 11 93 58 514
> Steuernummer: 105 5891 1000
> Please consider that invitations and e-mails of our institute are
> only valid if they end with …@mpie.de <https://urldefense.us/v3/__http:/mpie.de__;!!G_uCfscf7eWS!eslPb6ZEnby8M7NKRe_U_RT-95w2J8O2ngsc8rmrQVlMpEcB6ZTKlN2g65crXCWv7D2F9ubkzYI5nDpoeQ$>.
> If you are not sure of the validity please contact rco at mpie.de
> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
> aus unserem Haus nur mit der Endung …@mpie.de <https://urldefense.us/v3/__http:/mpie.de__;!!G_uCfscf7eWS!eslPb6ZEnby8M7NKRe_U_RT-95w2J8O2ngsc8rmrQVlMpEcB6ZTKlN2g65crXCWv7D2F9ubkzYI5nDpoeQ$> gültig sind.
> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Geschäftsführung
> Dr. Kai de Weldige
> only valid if they end with …@mpie.de.
> aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Geschäftsführung
> Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240311/646972ea/attachment-0001.html>
