[petsc-users] Bug in VecNorm, 3.20.3
Stefano Zampini stefano.zampini at gmail.com
Tue Jan 23 13:48:24 CST 2024
petsc main in debug mode has some additional checks for this cases. Can you
run with the main branch and configure petsc using --with-debugging=1?
Il giorno mar 23 gen 2024 alle ore 22:35 Barry Smith <bsmith at petsc.dev> ha
scritto:
>    This could happen if the values in the vector get changed but the
> PetscObjectState does not get updated. Normally this is impossible, any
> action that changes a vectors values changes its state (so for example
> calling VecGetArray()/VecRestoreArray() updates the state.
>    Are you accessing the vector values in any non-standard way?
>    Barry
> > On Jan 23, 2024, at 11:39 AM, michael at paraffinalia.co.uk wrote:
> > Hello,
> > I have used the GMRES solver in PETSc successfully up to now, but on
> installing the most recent release, 3.20.3, the solver fails by exiting
> early. Output from the code is:
> > lt-nbi-solve-laplace: starting PETSc solver [23.0537]
> >  0 KSP Residual norm < 1.e-11
> > Linear solve converged due to CONVERGED_ATOL iterations 0
> > lt-nbi-solve-laplace: 0 iterations [23.0542] (22.9678)
> > and tracing execution shows the norm returned by VecNorm to be 0.
> > If I modify the function by commenting out line 217 of
> >  src/vec/vec/interface/rvector.c
> >  /* if (flg) PetscFunctionReturn(PETSC_SUCCESS); */
> > the code executes correctly:
> > lt-nbi-solve-laplace: starting PETSc solver [22.9392]
> >  0 KSP Residual norm 1.10836
> >  1 KSP Residual norm 0.0778301
> >  2 KSP Residual norm 0.0125121
> >  3 KSP Residual norm 0.00165836
> >  4 KSP Residual norm 0.000164066
> >  5 KSP Residual norm 2.12824e-05
> >  6 KSP Residual norm 4.50696e-06
> >  7 KSP Residual norm 5.85082e-07
> > Linear solve converged due to CONVERGED_RTOL iterations 7
> > My compile options are:
> > PETSC_ARCH=linux-gnu-real ./configure --with-mpi=0
> --with-scalar-type=real --with-threadsafety --with-debugging=0 --with-log=0
> --with-openmp
> > uname -a returns:
> > 5.15.80 #1 SMP PREEMPT Sun Nov 27 13:28:05 CST 2022 x86_64 Intel(R)
> Core(TM) i5-6200U CPU @ 2.30GHz GenuineIntel GNU/Linux
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240123/76140fee/attachment.html>
