[petsc-users] MatAssemblyBegin freezes during MPI communication
Junchao Zhang junchao.zhang at gmail.com
Thu Jan 18 07:20:00 CST 2024
On Thu, Jan 18, 2024 at 1:47 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
> Dear PETSc Experts,
> My FEM program works well generally, but in some specific cases with
> multiple CPUs are used, it freezes when calling MatAssemblyBegin where
> PMPI_Allreduce is called (see attached file).
> After some investigation, I found that it is most probably due to
> ・ MatSetValue is not called from all CPUs before MatAssemblyBegin
> For example, when 4 CPUs are used, if there are elements in CPU 0,1,2 but
> no elements in CPU 3, then all CPUs other than CPU 3 would call
> MatSetValue  function. I want to know
> 1. If my conjecture could be right? And If so
No.  All processes do MPI_Allreduce to know if there are incoming values
set by others.  To know why hanging, you can attach gdb to all MPI
processes to see where they are.
2. Are there any convenient means to avoid this problem?
> Thanks,
> Xi YUAN, PhD Solid Mechanics
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240118/e4a02e03/attachment.html>
