[petsc-users] [Gmsh] Access both default sets and region names
Noam T. dontbugthedevs at proton.me
Fri Jan 12 04:25:55 CST 2024
Great.
Thank you very much for the quick replies.
Noam
On Thursday, January 11th, 2024 at 9:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 11, 2024 at 12:53 PM Noam T. <dontbugthedevs at proton.me> wrote:
>> There could be some overlapping/redundancy between the default and the user-defined groups, so perhaps that was the intended behavior. Glad to hear it's possible to have access to everything.
> Here is the MR: https://gitlab.com/petsc/petsc/-/merge_requests/7178
> If you build that branch, you can use -dm_plex_gmsh_use_generic to turn on those labels.
> Thanks,
> Matt
>> Thanks,
>> Noam
>> On Thursday, January 11th, 2024 at 6:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jan 11, 2024 at 11:59 AM Noam T. <dontbugthedevs at proton.me> wrote:
>>>> Without using the flag -dm_plex_gmsh_use_regions, the DMGetNumLabels says there are 5, named celltype, depth, cell/face/vertex sets.
>>>> With the flag, the labels are celltype, depth, my_vol, my_surface (using the same example as before).
>>>> Am I misusing the flag somehow, and I should be able to access those of cell/face/vertex as well?
>>> Shoot, yes this changed after another request. Yes, we can put in a flag for that. Should not take long.
>>> Thanks,
>>> Matt
>>>> PS: Using PETSc 3.20.3
>>>> Thanks,
>>>> Noam
>>>> On Thursday, January 11th, 2024 at 5:28 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Thu, Jan 11, 2024 at 11:18 AM Noam T. via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>>>> Would it be feasible to have an option (e.g. new flag along the lines of -dm_plex_gmsh_...) that allows the user to access both the default sets (Cell / Face / Vertex) together with user-defined gorups (those under $PhysicalNames, available when using -dm_plex_gmsh_use_regions)?
>>>>> I am not sure I understand the question. When you turn on regions, it makes extra labels, but the generic labels still exist.
>>>>> Thanks,
>>>>> Matt
>>>>>> That is, with a *.msh file containing
>>>>>> $PhysicalNames
>>>>>> 2
>>>>>> 2 100 "my_surface"
>>>>>> 3 200 "my_vol"
>>>>>> the return of DMGetLabelName(dm, n, name) would be (order may differ)
>>>>>> n = 0, name = "celltype"
>>>>>> n = 1, name = "depth"
>>>>>> n = 2, name = "Cell Sets"
>>>>>> n = 3, name = "my_vol"
>>>>>> n = 4, name = "Face Sets"
>>>>>> n = 5, name = "my_surface"
>>>>>> I poked into src/dm/impls/plex/plexgmsh.c and have managed to print all the labels after changing a couple of variable values, so perhaps it is doable.
>>>>>> The changes made are not a solution, simply naively set some variables to skip checking for the use_regions flag, so it understandably crashes soon after.
>>>>>> Thanks, Noam
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> [https://www.cse.buffalo.edu/~knepley/](http://www.cse.buffalo.edu/~knepley/)
>>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240112/5a6d97cf/attachment.html>
